2005 hyundai sonata as1414/1424
misterbmw
Posted: May 03, 2014 at 10:50 PM / IP Logged
Hello!
I have a next problem, battery in my RS died and i put a new one.
And now I have to link transmitter with RS module in my car.
I was trying next:
Case 1
2005 hyundai sonata as1414/1424 -- posted image.
Case 2
Parking lights stays on for 20 sec. as they should in programing mode.
In both cases, there are no reaction of parking light after holding LOCK button on RS.
I think my RS do not transmit signal.
My RS (red LED):
m.t/
sparkie
Platinum - Posts: 2,061
Posted: May 04, 2014 at 8:23 AM / IP Logged
Did you check the battery of the remote. Make sure it is good. Just because the remote's LED works means nothing. Many non name brand batteries are nearly dead when sold. Take the batteries out of the remote and check with a volt meter. Do you have a second remote to try to program?
sparky
misterbmw
Posted: May 04, 2014 at 10:15 AM / IP Logged
Yes I checked battery with voltmeter its shown 12V.
I don`t have another RS to check only one.
m.t/
sparkie
Posted: May 04, 2014 at 7:57 PM / IP Logged
The remote may be defective. Those remote starters don't loose programming when the batteries in the remote go dead. I assume we are talking about the remote's battery correct? If the battery in the vehicle was disconnected, you may have created a logic lock with the module. Unplug the 6 pin main power to the remote starter for 10 seconds and then reconnect it to clear the logic problem. The only other thing is to check the remote for bad connections on the circuit board. There are only a few which can be resoldered.
sparky
Monday, February 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
