another dei 530t issue, 2007 yaris
kaeon
Posted: May 30, 2014 at 7:32 AM / IP Logged
I have a 2007 Toyota Yaris Hatch that I just installed a 530T on and I am having a problem. The driver window works absolutely fine going up and down. However the passenger side goes down maybe halfway at the first click of the cars interior switch. I then have to click the interior switch a few more times to get it to go down all the way. I read up on the issue a little bit and greased the tracks, but that didn't help much. I hear about doing a resistor mod via the 1900 doc. However I am unsure which version I have.
another dei 530t issue, 2007 yaris -- posted image.
Posted: May 30, 2014 at 9:26 AM / IP Logged
Did you wire the passenger door from the driver's switch or did you go into each door?
The second answer is the only way to go.
kaeon
Posted: May 30, 2014 at 2:11 PM / IP Logged
Everything is wired to the drivers door master switch.
Posted: May 30, 2014 at 5:46 PM / IP Logged
Follow the instructions and place the unit in the middle of the car then wire directly to each motor.
Friday, December 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
