viper 5706v '06 chevy cobalt ss manual
coyn11
Member - Posts: 14
Posted: November 28, 2014 at 8:44 PM / IP Logged
I have been working 5 days all day trying to get this installed. I have done tons of research and have gotten pretty far in the installation. This is my first installation btw.
Viper 5706v + idatalink ads-alca connected W2W
I have connected what I think is everything that I need. Everything except siren and lights. I'm trying to remote start and during the MTS enabling as soon as I hit remote start on my fob it says "tenor start error" then nothing. What gives?
noob
coyn11
Member - Posts: 14
Posted: November 28, 2014 at 9:08 PM / IP Logged
On 5706v quick reference install guide...
6pin
1 - to constant 12v
2 - to chassis ground
3 - nc yet
4 - nc; also what is this?
5 - nc yet
6 - to GWR input blue/white idatalink(IDL)
3 pin
1 - to blue/black IDL
2 - NC
3 - to GREEN/ black IDL
10 PIN
1 - nc
2 - to ignition harness pin 4, acc
3 - nc
4 - nc
5 - to ignition harness pin 3, ign
6 - nc
7 - nc
8 - nc
9 - nc
10 - to ign harness pin 3, ign
24 pin
All nc unless specified
2 - connected to defogger relay switch
3 - to IDL RED / WHITE
4 - to relay switch
10 - to IDL yellow/red
12 - to IDL PURPLE / white
13 - to grounding relay triggered by e-brake
15 - to IDL yellow/black
16 - to horn relay switch
20 - to brake wire (energized when pressed, otherwise grounded)
noob
coyn11
Member - Posts: 14
Posted: November 28, 2014 at 9:13 PM / IP Logged
"Remote start error"*
noob
Platinum - Posts: 7,828
Posted: November 28, 2014 at 9:42 PM / IP Logged
6pin
1 - to constant 12v
3 - nc yet
5 - nc yet
6 - to GWR input blue/white idatalink(IDL)    This is GWA.  You want GWR connected to the bypass module.  Dark Blue (-) Status Output.
10 PIN
1 - nc
2 - to ignition harness pin 4, Goes to +12V
3 - nc
4 - nc
5 - to ignition harness pin 3, ign   Goes to +12V
6 - nc
7 - nc Starter
8 - nc ACC       to ign harness pin 4, Brown
9 - nc
10 - to ign harness pin 3, ign    Yellow
24 Pin add
Pin 5 Dark Blue (-) Status Output to IDL GWR Input
Posted: November 28, 2014 at 9:44 PM / IP Logged
Here is a really good wire guide listing with photo's : https://www.the12volt.com/installbay/file.asp?ID=717
coyn11
Member - Posts: 14
Posted: November 28, 2014 at 11:49 PM / IP Logged
kreg357 wrote:
6pin
1 - to constant 12v
3 - nc yet
5 - nc yet
10 PIN
1 - nc
3 - nc
4 - nc
6 - nc
7 - nc Starter
9 - nc
10 - to ign harness pin 3, ign  Â  Yellow
24 Pin add
Thank you so much for your reply! I made all the changes and read through the wiring guide for an 05. I have the service manuals for 06 so I am certain where my wires are. After the changes I am still getting "remote start error" and no clicks (no flashing lights) when I try to do the manual mode exit procedure. Tomorrow I'm going to install the siren and set it to automatic temporarily to see if I can get it to remote start. However, is there any info you need to correctly diagnose as to why I'm getting an error message?
Thanks again!
noob
Posted: November 29, 2014 at 4:20 AM / IP Logged
Next things to check :
Is the IDL ADS AL-CA flashed with the correct firmware?  Should be  ADS-AL(DL)-GM2.
Did you set the IDL Installation Mode to Standard ( W2W ), two blinks and lock it in?
Did the IDL program properly to the car?
Are you running the Viper in Tach Mode?  And did you do a successful Tach Learn?
coyn11
Member - Posts: 14
Posted: November 29, 2014 at 9:49 AM / IP Logged
FLASHED WITH CORRECT FIRMWARE
TWO BLINKS
IF THIS IS THE "OPEN THE DOOR, INSERT KEY FOR 3 SEC, TURN KEY ONE POSITION FOR 3 SEC, turn again for 3, and start for 3 then wait. Then yes. However it didn't do anything here. But I'll give it another go. However if my for locks and trunk work, do I need to do this?
TACH WIRE TO BYPASS AND LEARNED. (ONE FLASH)
noob
Posted: November 29, 2014 at 12:13 PM / IP Logged
At Step 6, did the IDL LED go Green for 2 seconds?  You must hold the key in START for at least 3 seconds while it learns the Passlock2 signal.
You might try the Viper Shutdown Diagnostics to check for the error code.
Think I would set the Viper Parking Light jumper/fuse to (-) and connect the H1/5 White wire to this vehcile wire :
PARKING LIGHTS ( - )       BROWN / WHITE (-)   @ HEADLIGHT SWITCH or BCM, GRAY 72-PIN PLUG(X2), PIN 5.
coyn11
Member - Posts: 14
Posted: November 29, 2014 at 3:29 PM / IP Logged
Good and bad news, I set the car in automatic mode and (while pressing down the clutch) got the car to remote start.
I know I need to bypass the clutch with a relay, I just haven't gotten around to that. I am getting 7 flashes when I do the shut down diag. following trying to set the car in manual mode and trying to do the exit procedure to remote start. I've read a lot of people having this issue just set the car in auto (even though they have a manual). But I don't see anyone actually solving this issue. And I don't want to set it to auto and one day accedently run over someone's kid.
BTW thank you for all your help so far!
noob
Wednesday, February 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
