Viper 5706v, 2011 Nissan Rogue
jstolk2
Member - Posts: 9
Posted: February 11, 2015 at 4:23 PM / IP Logged
In about an hour, I'll be attempting to install a Viper 5706V into a 2011 Nissan Rogue. It does not have the Intelli key. I have a DBALL which I have flashed for the Nissan firmware. I have never done a car this new before. I have never used a DBALL before. Anyone have any tips/pointers/concerns for me before I get started? I'm planning on using D2D.
jstolk2
Member - Posts: 9
Posted: February 11, 2015 at 7:12 PM / IP Logged
I'm at a point in the DBALL installation that says to find the "data" and "clock" on the NATS Antenna Connnector. I have no idea what that is. Any Help???
Platinum - Posts: 7,828
Posted: February 11, 2015 at 7:24 PM / IP Logged
You are looking for a White, 4 Pin connector at the ignition switch barrel.  Should be Green and Brown wires.
jstolk2
Member - Posts: 9
Posted: February 12, 2015 at 8:08 AM / IP Logged
Thank you. Ended up finding it. Everything worked out great. Pretty easy install once I found everything.
