04 Suburban, XK01 Remote Start, Door Lock Issue
jorgefdz
Copper - Posts: 99
Posted: March 21, 2015 at 9:18 PM / IP Logged Link to Post Post Reply Quote jorgefdz
CAR:  Chevy Suburban 2004
Alarm system : Avital 5303
Bypass Module: XK01 - AMDL 6.0
XK01 Connected thru D2D
So this mean I have connected D2D harness and Violet DATA (at the beginning).
because It didn't work... I finished hooking up also Door Lock and Unlock, Ground when Running and 12V & GND for W2W harness.
I thought I programmed correctly the first time to the type 4 it means suburban 2004.
I tried to remote start but it dies immediately.
Door Lock and unlock does not work neither.
I tried to reset the XK01 going to the 8 slow flashes, but cant reset it. I can not select the option no.2 that means reset (Unlock button at the avital remote).
I tried direct ground as I read in other Post, but cant not reset it.
I want to reset it, just in case I did not programmed correctly for my suburban.
any help will be appreciated...
j.f.l.l.
Platinum - Posts: 7,828
Posted: March 22, 2015 at 8:03 PM / IP Logged Link to Post Post Reply Quote kreg357
Not a big user of XresssKit modules ( especially the XK01 ) but if all else fails you could try using the XKLoader cable to flash it to something else and then back to AMDL firmware.  That should get you back to a fresh unit.
jorgefdz
Copper - Posts: 99
Posted: March 24, 2015 at 4:51 PM / IP Logged Link to Post Post Reply Quote jorgefdz
I tried to re-flash using the XKLoader but I notices that I cant use it anymore if you are not a dealer/member at expresskit web site, is this correct?
j.f.l.l.
Posted: March 24, 2015 at 5:41 PM / IP Logged Link to Post Post Reply Quote kreg357
I don't think so.  I just plugged in the XKLoader2 cable with an XK01 attached and went to  https://www.directechs.com/ .
It recognized the XKLoader ( upper right XpressVIP 4.5 box ) and showed the Platform 1 module with AMDL V6.00 firmware.
I wasn't logged in.  You should be able to do everything except "Key-to-Go" as a non-dealer.
jorgefdz
Copper - Posts: 99
Posted: March 25, 2015 at 11:38 AM / IP Logged Link to Post Post Reply Quote jorgefdz
You are right, I can do that.
But where is the option to reflash it on the webpage?
Thanks.
j.f.l.l.
tedmond
Gold - Posts: 4,610
Posted: March 25, 2015 at 1:04 PM / IP Logged Link to Post Post Reply Quote tedmond
once you start xpressvip, it should detect your loader + bypass. Then you can flash by vehicle or firmware
Ted
Compustar Expert
el ranchero
Copper - Posts: 92
Posted: March 25, 2015 at 9:06 PM / IP Logged Link to Post Post Reply Quote el ranchero
i say boycott xpress for doing this
rocker
Posted: March 25, 2015 at 9:44 PM / IP Logged Link to Post Post Reply Quote kreg357
For this vehicle, the Fortin INT-SL+ is excellent.  Can't go wrong with iDatalink, either.
tedmond
Gold - Posts: 4,610
Posted: March 26, 2015 at 10:45 PM / IP Logged Link to Post Post Reply Quote tedmond
^^^^ 04 Suburban, XK01 Remote Start, Door Lock Issue -- posted image.
Ted
Compustar Expert
jorgefdz
Copper - Posts: 99
Posted: March 27, 2015 at 8:43 AM / IP Logged Link to Post Post Reply Quote jorgefdz
Thanks to all the people that take some time to reply my post.
I ending buying a another bypass/lock module.
I changed to OMEGA brand.. and wired W2W it was so easy and fast not as Xpresskit LOL.
Thank you again.!
j.f.l.l.
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
