2006 GMC Yukon Viper 5906v Remote Start
evotires
Member - Posts: 13
Posted: July 18, 2015 at 6:23 PM / IP Logged Link to Post Post Reply Quote evotires
So it's been a while since I've installed any alarms or remote start systems (about 6 years ago I worked at a shop). I'll admit I've been out of the game for a while now.
I'm installing a 5906v into a 2006 GMC Yukon Denali. I'm using an XK09 and after many failed attempts, I believe it is finally programmed and running the door locks, etc.
I'm having trouble with the remote start. It will not crank the starter. I have cut the Yellow starter wire and used the green and violet wires from the brain. When I try to Remote start, it will turn on the ign and acc, but will not send voltage to the starter wires (green or violet).
For the most part, I followed these instructions: https://www.the12volt.com/installbay/forum_posts.asp?tid=128571&tpn=1#639574
I'm guessing I have a wire or 2 wrong somewhere? Picture for further reference.
2006 GMC Yukon Viper 5906v Remote Start -- posted image.
Platinum - Posts: 7,828
Posted: July 18, 2015 at 7:12 PM / IP Logged Link to Post Post Reply Quote kreg357
The Starter wire cut and wiring looks OK.  Here is a link to a Pictorial on this style vehicle :
https://www.the12volt.com/installbay/forum_posts.asp?tid=133000   Might be of some help.
Have you programmed the Viper to Auto Trans Mode?  Have you programmed the Viper to Tach Mode and successfully done a Tach Learn?
You could try the Viper Shutdown Diagnostics to see if it is logging an error.
Posted: July 19, 2015 at 2:11 AM / IP Logged Link to Post Post Reply Quote howie ll
One problem might be those connectors, solder joints please. Look at your yellow tube connectors where you've cut the starter, you aren't crimping them properly. Those wires will pull out in no time.
evotires
Member - Posts: 13
Posted: July 19, 2015 at 12:43 PM / IP Logged Link to Post Post Reply Quote evotires
Thanks for the quick replies.
I have successfully programmed the viper into automatic mode, and have also learned the tach. I will check to see if it is maybe in "virtual tach" mode?
When I Remote start from the remote, I have to shut it down myself either via remote or pressing the brake pedal. Otherwise it will "run" (never actually starting, just leaving the ign/acc on) until I shut it down/deactivate. I haven't let it sit that long, but I assume it would stay on the entire 12 minutes.
I CAN start the car using the key still.
Posted: July 19, 2015 at 3:22 PM / IP Logged Link to Post Post Reply Quote howie ll
Shut down via brake pedal or remote is normal. Runs for the time you set in the programming.
evotires
Member - Posts: 13
Posted: July 20, 2015 at 1:02 AM / IP Logged Link to Post Post Reply Quote evotires
I understand those, But it's not actually starting the car.
Posted: July 20, 2015 at 4:08 AM / IP Logged Link to Post Post Reply Quote howie ll
List what you've connected to where please.
Posted: July 20, 2015 at 4:11 AM / IP Logged Link to Post Post Reply Quote howie ll
And throw away the POS PK and use a DB-ALL2, you'd be amazed at how simple it then becomes.
evotires
Member - Posts: 13
Posted: July 23, 2015 at 12:03 PM / IP Logged Link to Post Post Reply Quote evotires
Viper 5906V ____________________      Yukon
1.Pink (+)Ignition 1 Input/Output         - Pink wire, shows +12V in run and start positions
2.RED / white (87) Flex (30A Fused)           - NC
3.Orange (+)Accessory Output                 - Orange wire, shows +12V in run but not start position
4.Violet (+)Starter Output (Car Side Of Starter Kill) - Starter side of purple wire (cut), shows +12V in start position
5.Green (+)Starter Input (Key Side Of Starter Kill)  - Ignition switch side of above purple wire
6.Red Ignition 1 Input (30A Fused)   -  Red @ Ignition Switch Harness
7.Pink/White (30) Flex Relay Output  - White (looks almost light yellow) @ Ignition Switch Harness
8.Pink/Black (87a) Flex Relay Input   - NC
9.RED / Black Acc/Starter (30A Fused) - Red @ Ignition Switch Harness
10.No Connection
Brown ACC2 wire at ignition switch harness requires SPDT relay:
Pin 85 to Viper Orange (-)200mA Accessory2 Output
Pin 86 and 87 to +12V Constant thru 20A fuse
Pin 30 to Brown ACC2 @ Ignition Switch Harness
Pin 87A not used - insulate
And for the XK09:
Only the solid lines are hooked up exactly how it says on the paper. Using D2D.
evotires
Member - Posts: 13
Posted: July 23, 2015 at 12:12 PM / IP Logged Link to Post Post Reply Quote evotires
I am using an XK09. Which I am thinking is the main issue I'm having. I cannot get it to program (again). Don't remember how I got it programmed the first time, but I tried to re-flash it again this morning, and now cannot get it to program at all. Called directed for some tech support and I cannot get tech support unless I'm an authorized dealer2006 GMC Yukon Viper 5906v Remote Start -- posted image.
I might have to look at the DB-ALL2, maybe it's easier to program?
Page of 3
