If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
Also is there a way to test the relay to see if its working? I accidentally connected the three pin connected in to the 556u immobilizer bypass by mistake. When there was a different three pin connect that was supposed to go in to that 556U.
