If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
Wednesday, December 24, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
I am on board with his suggestion of having hard wire the door trigger and diode isolate a signal to kill the retained accessory power at the drivers door.
I can't seem to figure out which signal i should use to kill the RAP.
I think i can completely disable the factory alarm system and use the "Factory alarm arm" wire cn5 pin 11 (Orange wire) to kill retained accessory power? so long as it is diode isolated from the door trigger wire...
Sound right?
any ideas?
again this is a Compustar CM7000
Thanks for any help guys!
