How to wire Starter Kill with 2 starter wires?
mduong25
Member - Posts: 23
Posted: October 16, 2015 at 1:20 PM / IP Logged Link to Post Post Reply Quote mduong25
If your vehicle has 2 starter wires, how would you wire a starter kill setup using a relay? And How do you determine if you will use a normally open or normally closed wiring setup? Is it vehicle dependent? And are diodes necessary?
Posted: October 16, 2015 at 4:19 PM / IP Logged Link to Post Post Reply Quote howie ll
You'll only need it on the wire designated as starter 1.
Standard type.
5 pin relay mandatory wiring and pin positions.
GWA (ground when armed) to 85.
Ign (live when cranking) to 86
Ign. sw. side to 87a
Starter side to 30
87 not used.
1N4004 diode across 86 and 85, band to 86.
That's a normally closed type, IMO of 40+ years experience s the only type to use, it's fail safe.
Posted: October 16, 2015 at 4:22 PM / IP Logged Link to Post Post Reply Quote howie ll
I don't even know why you're posting, can't you see where this was already answered in another of your posts?
Sunday, July 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
