Fortin module + Avital 4103 in 2005 4runner
clirizarry
Posted: November 05, 2015 at 9:44 PM / IP Logged Link to Post Post Reply Quote clirizarry
I have looked everywhere to solve this puzzle, so here I am.
I have installed on my Toyota 2005 4runner a Fortin Key-Override-All (flashed for the 4runner) following the diagram where the blue wire from the inmobilizer harness shows a remote symbol for the remote start.It is labeled (-)"while running".
Fortin module + Avital 4103 in 2005 4runner -- posted image.
Fortin diagram
The Avital 4103 has a 4 pin connection called "Satellite Harness".
This harness has pin 1 (blue wire) labeled (-)200mA Status Input.
Is this Avital 4103 blue wire the one I connect to the blue Fortin (-) "while running" input?
This installation has been a bear (3 days @4-6 hrs each day) mostly because of the scarcity of information online on the location of most wires, and then poor (sometimes contradictory) direction from most wiring directions. Challenging...And I am a $%&# Electrical Engineer!
In contrast, the remote start on my 2007 Jeep Grand Cherokee was a snap as it was plug and play, at about 1 1/2 hr!
This forum has been invaluable.
Any help will be appreciated!
I am almost done.
triniforever
Copper - Posts: 323
Posted: November 05, 2015 at 9:57 PM / IP Logged Link to Post Post Reply Quote triniforever
There is a plug on the 4103 that has a Grey ,Brown , PURPLE / White, BLACK/ White and Blue/White wires , use the Blue/White wire to connect to the Blue wire on the Fortin .
triniforever
clirizarry
Posted: November 07, 2015 at 10:59 PM / IP Logged Link to Post Post Reply Quote clirizarry
Thanks for your help Triniforever. I tried your suggested connection, but it did not work with the Fortin disabler.
Turns out the H1(4) WHITE/ blue wire was a single pulse signal input (not steady state ground) for activation on the remote start sequence. It could have been programmed to 2 or 3 pulses activation of the remote.
The Fortin worked with the Satellite steady ground provided from the blue wire.
I obviated the D2D connection because the wiring for the Fortin did not match the the Avital 4103 plug and vice-versa. I used the alternate wiring.
For those that need a step by step manual for the Avital 4103 here it is..
The initial startup was a failure. the Fortin did not behave as stated in the programming section and the car did not start. I started it with key and drove for 5 minutes. when the test drive was over, the remote start did work when activated.
Anyone with a GEN4 Toyota 4runner that needs help, drop me a message. this has been the most complicated vehicle ever to install electronic equipment and i will be happy to help.
triniforever
Copper - Posts: 323
Posted: November 08, 2015 at 12:37 PM / IP Logged Link to Post Post Reply Quote triniforever
I said Blue /White not WHITE/ Blue!
triniforever
clirizarry
Posted: November 08, 2015 at 2:35 PM / IP Logged Link to Post Post Reply Quote clirizarry
OOps! My bad, yeah it is as you said, I guess dyslexia claimed another victim.
Sunday, July 13, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
