2001 chevy surburban, viper 4105v rs, idatalink
wyciwug
Copper - Posts: 158
Posted: April 16, 2016 at 7:32 PM / IP Logged Link to Post Post Reply Quote wyciwug
Hello
I am about doing rs one way viper 4105v and idatalink bypass. I have a question about this. Can someone tell me what it meant and what do i need to do
? Thanks
To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
dcd
chev104275
Gold - Posts: 1,436
Posted: April 17, 2016 at 4:40 AM / IP Logged Link to Post Post Reply Quote chev104275
The wire must be powered like an ignition (12v through cranking). Verses accessories which is (12v drops out when cranking)
wyciwug
Copper - Posts: 158
Posted: April 17, 2016 at 8:21 AM / IP Logged Link to Post Post Reply Quote wyciwug
hello
Do i connect the PINK/WHITE wire from remote start to vehicle second Ignition #2: WHITE normally?
Pink wire from remote start to vehicle's Pink wire ignition #1?
dcd
wyciwug
Copper - Posts: 158
Posted: April 17, 2016 at 11:15 AM / IP Logged Link to Post Post Reply Quote wyciwug
Got it thanks
dcd
wyciwug
Copper - Posts: 158
Posted: April 28, 2016 at 7:27 PM / IP Logged Link to Post Post Reply Quote wyciwug
hello
I got the vehicle started now but there is a problem
Customer said driver side window roll down when starting the car sometimes, not all the times
Also alarm went off sometimes when starting also. Do I connect unlock wire from remote start to alarm disarm wire in vehicle?
What is the cause of the window to roll down sometimes when remote start?
D
dcd
chev104275
Gold - Posts: 1,436
Posted: April 29, 2016 at 4:49 AM / IP Logged Link to Post Post Reply Quote chev104275
Where is the disarm wire from the 4105 connected ?
wyciwug
Copper - Posts: 158
Posted: April 29, 2016 at 9:18 AM / IP Logged Link to Post Post Reply Quote wyciwug
I didn't use that wire. I should reuse it now right?
dcd
chev104275
Gold - Posts: 1,436
Posted: April 29, 2016 at 10:24 AM / IP Logged Link to Post Post Reply Quote chev104275
if it has a factory alarm you will need it connected
Factory Alarm Disarm lt. green (driver door key cylinder) - BCM, purple plug, pin B3
Notes: The BCM (Body Control Module) is under the driver dash.
