2006 GT Mustang Disable Factory Alarm
stang628
Posted: July 24, 2016 at 4:08 PM / IP Logged Link to Post Post Reply Quote stang628
How do I disable the factory alarm. Do I permanently ground the "Factory Alarm Disarm"?
lurch228
Silver - Posts: 1,338
Posted: July 24, 2016 at 6:03 PM / IP Logged Link to Post Post Reply Quote lurch228
No it just needs to be pulsed.
stang628
Posted: July 24, 2016 at 6:24 PM / IP Logged Link to Post Post Reply Quote stang628
When the aftermarket alarm locks/unlocks, I need a relay setup to "pulse" the factory alarm lock/unlock circuit? In effect telling the factory alarm that the doors are locked/unlocked?
lurch228
Posted: July 24, 2016 at 7:00 PM / IP Logged Link to Post Post Reply Quote lurch228
Your aftermarket alarm should have the needed wires to do that no relay needed. typically a negative pulse. What make/model of alarm is it?
stang628
Posted: July 24, 2016 at 7:25 PM / IP Logged Link to Post Post Reply Quote stang628
Python 3105P. The lock and unlock wires, would I tee off them and go to the factory arm and disarm wires?
lurch228
Posted: July 24, 2016 at 8:44 PM / IP Logged Link to Post Post Reply Quote lurch228
With that system yes as it doesn't have arm disarm outputs.
stang628
Posted: July 24, 2016 at 8:53 PM / IP Logged Link to Post Post Reply Quote stang628
So, when I arm and disarm the Python, it will also arm and disarm the factory alarm. The car will have 2 active alarms.
lurch228
Posted: July 24, 2016 at 11:09 PM / IP Logged Link to Post Post Reply Quote lurch228
Yes but the factory can't be permanently disabled, at least not easily that is.
stang628
Posted: July 24, 2016 at 11:15 PM / IP Logged Link to Post Post Reply Quote stang628
Thank for your help Lurch228. I will make the wiring mods tomorrow.
lurch228
Posted: July 25, 2016 at 12:29 AM / IP Logged Link to Post Post Reply Quote lurch228
No problem.
