DEI 5x10 in 2011 Acura TSX navigation edition
jjalarm
Posted: December 06, 2016 at 1:23 PM / IP Logged Link to Post Post Reply Quote jjalarm
I have a question about diodes and 12 volt constant in my alarm installation. I want to add a fuse to my driver’s side fuse box and extend a 12 volt constant from it to my backup battery 520T and to the red wires on my tilt sensor (507M) and proximity sensor (508D)--all three of these will have fuse even though the fuses are not shown in the diagram below.
I was wondering, do I need to add diodes to separate the 12 volt constant from the 520T, 507M, and 508D, such as shown in my diagram, or are these diodes not needed?
Here is my wiring diagram:
DEI 5x10 in 2011 Acura TSX navigation edition -- posted image.
bogucki
Copper - Posts: 91
Posted: December 12, 2016 at 2:37 AM / IP Logged Link to Post Post Reply Quote bogucki
hey
i would say the diodes on the power wires are not needed, only the alarm signal/trigger wires would need to be diode isolated if using the same wire, the power wires should have separate fuses.
boguckialex
Thursday, July 3, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
