2013 highlander keystart/viper 4806v/ alcaads
wyciwug
Copper - Posts: 158
Posted: February 22, 2017 at 9:04 PM / IP Logged Link to Post Post Reply Quote wyciwug
I got this diagram drawed up for the wirings for up coming car im going to do.
Can somebody correct me if im wrong please
2013 highlander keystart/viper 4806v/ alcaads -- posted image.
dcd
wyciwug
Copper - Posts: 158
Posted: February 23, 2017 at 11:31 AM / IP Logged Link to Post Post Reply Quote wyciwug
hello all
The Idata link wiring diagram is showing Parking light connection between Remote starter 4806v to car's white connector pin #18. Where do I find this wire from the Remote start? As for the trunk/lift gate (-) output, will that be the RED / white wire from the 24-pin Harness?
Thanks members.
dcd
silvercivicsir
Copper - Posts: 416
Posted: February 23, 2017 at 11:47 AM / IP Logged Link to Post Post Reply Quote silvercivicsir
it's the thick white wire from the viper brain (make sure to change it to negative)
wyciwug
Copper - Posts: 158
Posted: February 23, 2017 at 11:49 AM / IP Logged Link to Post Post Reply Quote wyciwug
The only thing I see is
Main Harness, 6-pin connector
H/5 White- Pin 30 of light flash relay.
What does this mean?
dcd
silvercivicsir
Copper - Posts: 416
Posted: February 23, 2017 at 3:46 PM / IP Logged Link to Post Post Reply Quote silvercivicsir
yup thats the wire you want to use, when you insert the fuse (under the cover), make sure to select negative light flash
