2010 Armada Seat and SW Heater relay
d16apwr
Posted: October 18, 2017 at 8:49 PM / IP Logged Link to Post Post Reply Quote d16apwr
All,
I'm installing a Clifford 4606x into a 2010 Nissan Armada Platinum. I wanted to use the second status out (defogger) to turn on the heated seats to high, as well as turn on the steering wheel heater. This output goes to ground normally when the temperature is below 55 deg. F in the cabin. I've included my planned relay connections to accomplish this. Just looking for some input on if this is correct or not. All connections to the alarm (-) output will be diode isolated. Also, both the seat heater switches, as well as the steering wheel heater, are all latched switches.
Thanks!
2010 Armada Seat and SW Heater relay -- posted image.
d16apwr
Posted: November 02, 2017 at 1:08 PM / IP Logged Link to Post Post Reply Quote d16apwr
In case anyone else ever hits this, I wired it up as I illustrated above and everything works as it should.
