2017 Toyota Tacoma, alarm/remote start
luism21
Member - Posts: 16
Posted: October 22, 2017 at 9:54 PM / IP Logged Link to Post Post Reply Quote luism21
looking to see if anyone has the 2017 toyota tacoma alarm/remote start wiring diagram. and if they have had any tips. planning on using idatalink bypass.
loganemakf
Member - Posts: 33
Posted: October 28, 2017 at 8:26 AM / IP Logged Link to Post Post Reply Quote loganemakf
Standard key, automatic transmission? If so, it looks like the blade-al install guide lists all the necessary connections (and handles oem alarm control, door lock/unlock/stat, brake pedal input, tach, and hood stat if the truck is equipped with a hood pin already).
luism21
Member - Posts: 16
Posted: October 28, 2017 at 10:31 PM / IP Logged Link to Post Post Reply Quote luism21
its automatic with the standard or H key sr5 if it makes a difference
having a problem with idatalink alca it will program right and all features seem to work but, when i try to remote start it the programming light turns steady red. tried remote starting with the key in the ignition and it starts, anyone have an idea of why it seems like the bypass dont seem to bypass immobilizer?
Platinum - Posts: 7,828
Posted: October 29, 2017 at 4:27 PM / IP Logged Link to Post Post Reply Quote kreg357
What R/S unit are you using?
Are you going D2D or W2W?
Did you set the ADS AL-CA Installation Mode to one blink for Data or 2 blinks for Standard and lock it in prior to bypass to vehicle programming?
shark mobile
Copper - Posts: 83
Posted: November 11, 2017 at 8:55 PM / IP Logged Link to Post Post Reply Quote shark mobile
Canh canl wires backwards?
Immobilized wire wrong...or if a cut backward...connector side vehicle side.
Program a tach? Or hardwire one if no virtual tach exists
Ensure the right bypass is a selected in the RS programming.
So much to go wrong...
Solder, tape, repeat!
