2003 Lexus ES300 Trunk Release Wiring
mduong25
Member - Posts: 23
Posted: November 02, 2017 at 12:01 PM / IP Logged
Installing a viper 4706v on a 2003 lexus es300, in the wiring diagram for trunk release it says to use the "5-wire" method. However I am trying to determine if the car has a negative or positive trunk polarity/release because there are diagrams for each type. Can someone help with this question and let me know how to wire this up?
Thank you,
Mike
Platinum - Posts: 7,828
Posted: November 02, 2017 at 12:21 PM / IP Logged
Your Viper has only a (-) Trunk Release Output as shown below :
RED/WHITE (-) 200mA TRUNK RELEASE OUTPUT
The only info I can find for your 2003 ES300 is this :
TRUNK RELEASE     WHITE/BLUE (5-WIRE)     IN DRIVERS KICK PANEL
Here is a link to the relay wiring diagram from Bulldog Security :
http://diagrams.marktoonen.nl/DOWNLOADS/17044_ES300_5-WIRE%20TRUNK%20RELEASE%20DIAGRAM.pdf
A few notes :
You need a 30/40 Amp SPDT Bosch style relay with 5 wire harness.
You need an inline fuse holder with 10 Amp fuse.
You will use the top diagram. Your relay harness wire colors / positions will probably not match the diagram.
Basically it will go like this using relay pin numbers :
Relay Pin 85 to Viper RED/WHITE (-) 200mA TRUNK RELEASE OUTPUT
Relay Pins 86 and 87 to +12V constant through the 10 Amp fuse
Relay 87a to the cut WHITE/BLUE wire IN DRIVERS KICK PANEL going towards front of the car
Relay Pin 30 to the cut WHITE/BLUE wire IN DRIVERS KICK PANEL going towards rear of the car
mduong25
Member - Posts: 23
Posted: November 02, 2017 at 1:51 PM / IP Logged
Thank you!
Posted: November 03, 2017 at 12:41 PM / IP Logged
1N4004 diode across 85 and 86, band to 86.
Or say goodbye to the 24 pin plug on the Viper.
mduong25
Member - Posts: 23
Posted: November 03, 2017 at 4:45 PM / IP Logged
howard, if you are using a diode from 85 to 86, which is a negative to a constant power source....is that going to be a problem? I don't understand much about diodes...so i apologize in advance. thank you. According to the diagram...i am fusing 86&87 with 12v constant and 85(-) is the trunk wire from the unit.
Posted: November 03, 2017 at 5:04 PM / IP Logged
The diode stops back feed, around 200 volts when the relay shuts down, it can destroy the circuits above, also known as a quenching diode.
Well worth spending a few cents.
