2000 Cherokee XJ, Avital 4103
wtmaxx25
Posted: November 05, 2017 at 5:00 PM / IP Logged Link to Post Post Reply Quote wtmaxx25
The wiring for Nuetral safety shows (-)input on a vital system, the 12vokt diagram says yellow (+) at ignition switch... help with this please.
Ween
Platinum - Posts: 1,368
Posted: November 05, 2017 at 5:45 PM / IP Logged Link to Post Post Reply Quote Ween
For automatic transmission should be black/white (neg) at starter relay in PDC. For manual transmission, the clutch safety switch is yellow (pos).
wtmaxx25
Posted: November 05, 2017 at 5:56 PM / IP Logged Link to Post Post Reply Quote wtmaxx25
Awesome thank you, I was told to install the toggle switch to ground lol!
wtmaxx25
Posted: November 06, 2017 at 11:22 AM / IP Logged Link to Post Post Reply Quote wtmaxx25
Ok so new question, courtesy lamp input or out put for avital 4103 doesn't show up on 9 pin main harness, it only shows fact disarm, arm, ignition out and ground/anti g rt ground output. Also there is a 4 pin satellite harness.directed is not much help unless a dealer...
Ween
Posted: November 06, 2017 at 7:24 PM / IP Logged Link to Post Post Reply Quote Ween
There isn't a dome light supervision output on the 4103. If you added a 528T timer triggered off the unlock output, the timer contacts could operate the dome light.
Thursday, December 11, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
