2000 Silverado Flashing Lights
tdbaker021
Copper - Posts: 98
Posted: November 23, 2017 at 10:11 PM / IP Logged Link to Post Post Reply Quote tdbaker021
I have a 2000 Silverado with an Excalibur AL-2060-EDPB RS. I want to have my DRL and Reverse lights come on when I disarm the alarm and or RS the system. I hooked it up once using diodes and it worked perfectly until I seen one of my diodes were getting to hot. Would a higher amp diode (5-10amp) work? I tied into the RS flashing light wire with one diode (This one got to hot) and then tied into the DLR and reverse light using a diode so my reverse lights would not come on with my DRL's.
Also I noticed that when I disarm the alarm and my parking lights come on the truck chimes like the door is open or the lights are left on. Is there anyway to stop the chime from going off? Right now I have my lights hooked up to the (+).
Platinum - Posts: 13,723
Posted: November 25, 2017 at 8:39 AM / IP Logged Link to Post Post Reply Quote i am an idiot
The diode does need to be sufficient amperage to handle the current draw of the lights.
Posted: November 25, 2017 at 11:51 AM / IP Logged Link to Post Post Reply Quote howie ll
Go to a 3amp diode (1N5404) for the DRL's, use a relay for the back-up lights.
tdbaker021
Copper - Posts: 98
Posted: November 25, 2017 at 8:37 PM / IP Logged Link to Post Post Reply Quote tdbaker021
Ok I'll give that a try. thanks
tdbaker021
Copper - Posts: 98
Posted: November 26, 2017 at 7:04 PM / IP Logged Link to Post Post Reply Quote tdbaker021
anything I can do about the dinging when I disarm the alarm and the parking lights are on?
Monday, November 24, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
