2010 MKZ, remote start
big_bogus
Member - Posts: 23
Posted: December 19, 2017 at 10:24 AM / IP Logged Link to Post Post Reply Quote big_bogus
Trying to install add on remote start. Only problem is I can't find the lock motor (gray/brown or blue/green wire ?? not sure which). I have the drivers side kick panel out and the bundle of wires accessible BUT I cannot find a blue/green and gray/brown doesn't test correct. Any hints or pictures would be great. Hate to take the door panel off, but need to get this done today as the weather is VERY nice for now.
geepherder
Platinum - Posts: 3,668
Posted: December 19, 2017 at 12:50 PM / IP Logged Link to Post Post Reply Quote geepherder
http://diagrams.marktoonen.nl/printlist.aspx?MakeID=28&ModelID=20027
The color may be different, but Bulldog has power lock as pin 17 of the SJB grey 26 pin plug (C).
This will hopefully keep you from having to run wire into the door. Otherwise:
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=177070
chev104275
Gold - Posts: 1,436
Posted: December 19, 2017 at 4:48 PM / IP Logged Link to Post Post Reply Quote chev104275
The wire listed above is the switch wire and won't work for what your trying to do
You want the
LOCK MOTOR WIRE     GRAY/BROWN (5-WIRE TYPE)     IN DRIVERS KICK PANEL
That way it will pulse when using the key fob
big_bogus
Member - Posts: 23
Posted: December 19, 2017 at 4:51 PM / IP Logged Link to Post Post Reply Quote big_bogus
Thanks for the info. I have completed the install. It seems the the gray/brown in the kick panel was + activation vs all of the - I read. It is working fine now.
