Installing Two Shock Sensors
69-er
Member - Posts: 18
Posted: March 04, 2018 at 8:38 PM / IP Logged Link to Post Post Reply Quote 69-er
Two questions actually:
I am thinking about installing two shock sensors on my 66 Chevy truck. Not sure if it is overkill or would cause problems. I would like to install one in the rear to protect the rear of the bed, specifically the tailgate. And, install another in the cab as usual.
The alarm is a a Viper 5706V. It has two sensor ports so it seems logical you could connect two of any type of sensor. The installation guides I have do not address using these ports other than showing the ports in a diagram. Am I good to go by installing a shock sensor in each port? (Assuming it's a good idea to begin with).
eguru
Copper - Posts: 340
Posted: March 05, 2018 at 8:04 AM / IP Logged Link to Post Post Reply Quote eguru
Should work fine.
Will the tailgate sensor just detect that it has been lowered? If so, a tilt switch would work as well.
stanward
Copper - Posts: 57
Posted: August 15, 2018 at 7:43 PM / IP Logged Link to Post Post Reply Quote stanward
I installed two shock sensors on my Frontier, one in the tailgate and another in the dash. I had the trigger wire of the tailgate shock sensor go to the "trunk pinswitch port".
Friday, November 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
