97 Expediton, 4300 Avital with DEI 556u Bypass
getmurphed
Posted: April 14, 2018 at 3:11 PM / IP Logged Link to Post Post Reply Quote getmurphed
I have a 97 expedition im trying to install a avital 4300 in here is what i have please correct anything if it is wrong and do i need a 451m relay module i also have the dei 556u bypass module.
Primary harness H1
armed output   orange to ground
light flash    white to brown at switch
remote start activation       white/blue to blue on the 556u
dome light    optional?       black/white to ?
door trigger -green to blue/white
multiplex    needed?          blue to
door trigger + needed?       violet to
ground        black to ground
empty
siren +     brown to + of siren
2 channel validity        red/white to ?
auxiliary harness H2
factory disarm              light green/black to dark green/purple
factory rearmgreen/white to ?
programmable channel 4      necessary?
programmable channel 5      necessary?
wait to startnecessary?
second unlock output        necessary?
door lock harness 3 pin
green to   pink/lt green
blue to   pink/yellow
I'm having a hard time finding these only can find them at the switch.
remote start ribbon
ign2 acc2 relay turn on       pink/white to
ignition input to alarm       yellow to
ignition relay turn on        pink to
accessory relay turn on       orange to          all connected to heavy gauge relay satellite
starter relay turn on        purple to
anti grind     orange/black to
status        blue to
output to starter                          purple to red/lt blue
starter input from ign green to red/lt blue
12v high current                 red to yellow
output to accessory     orange to grey/yellow
output primary ignition pink to blue/green
high current 12v        red to other yellow
output to secondary ignition           pink/white to black/green
high current            red/white   don't cut
the car does have a 3rd ignition labeled as to transmission   do i need this?
remote start harness   H3
2nd status rear defogger              blue/white to necessary? blue on 556u ?
hood pin switch        grey to hood pin switch
brake shutdown        brown to light green at top of brake pedal
tach    violet/white to necessary?
neutral safety switch black/white to necessary?
dei 556u remote bypass
12v constant            red to yellow or other 12constant
status input            blue to white/blue   on primary harness
true ignition input     pink to ?
key sense input +       violet to ?
key sense input   -     green to ?
or would it be better to use the alternate wiring and the 3 wire plug.
thank you in advance for any assistance.
bs
getmurphed
Posted: April 15, 2018 at 11:29 PM / IP Logged Link to Post Post Reply Quote getmurphed
help please anyone
bs
Platinum - Posts: 7,828
Posted: April 17, 2018 at 6:23 PM / IP Logged Link to Post Post Reply Quote kreg357
Not familiar with Avital 4300 unit but.......
Primary harness H1
armed output           not used
light flash white to brown at switch   * set to (+) output
remote start activation          not used
dome light optional
door trigger -            green to blue/white
multiplex        blue to
door trigger             not used
empty
factory Alarm Rearm green/white to ?
programmable channel 4            not used
programmable channel 5            not used
wait to start   not used
second unlock output   not used
green to             pink/lt green            Type B with factory keyless entry
blue to pink/yellow
Keyless Module under driver dash or PKP.
Type C REV without factory keyless entry use the 451M Door Lock Module for Type C locks.
remote start ribbon
ign2 acc2 relay turn on       pink/white to 30/40 Amp SPDT relay Pin 85
status        blue to ( could be used for 556UW Status Input instead of Blue/White )
output to starter           purple to red/lt blue     ** cut wire - vehicle side
starter input from ign   green to red/lt blue      ** cut wire - ign switch side
output primary ignitionpink to dar blue/light green
output to ignition 2      pink/white to black/green
high current   red/white to light green/purple
the car does have a 3rd ignition labeled as to transmission   do i need this? yes
Pin 85 to IGN2 (-) above
Pin 86 and 87 to +12V constant light green/purple through 30 Amp fuse
Pin 30 to Red/Black IGN3
2nd status rear defogger              blue/white to blue on 556u
tach violet/white to Pink/White @ Coil
neutral safety switch     black/white to Chassis Ground if auto trans
status input             blue to blue/white on H3 harness
true ignition input     pink to red/lt blue
key sense input +       not used
key sense input   -     green to BLACK/PINK (-) @ IGNITION SWITCH HARNESS
Does the truck have Factory Remote Keyless Entry? no = need 451M
Does the truck have a chipped key? yes = need 556UW
getmurphed
Posted: May 17, 2018 at 7:39 AM / IP Logged Link to Post Post Reply Quote getmurphed
where is the green/purple wired located
thank you
bs
Posted: May 17, 2018 at 2:37 PM / IP Logged Link to Post Post Reply Quote kreg357
It should be at the main ignition switch harness. Typical Ford trucks have several Yellow and
Light Green/Purple wires there that will test as +12V constant. Always verify and test with a
Digital Multi Meter before making any wire connections. If you find multiple +12V constant wires
at the ignition switch, it is best to split the Viper R/S load between them.
getmurphed
Posted: May 21, 2018 at 11:23 AM / IP Logged Link to Post Post Reply Quote getmurphed
Thank you for your quick response so when i wire up the relay for the 3rd ignition the car behaves as if the key is in the ign in the acc position. As in car stereo is on power windows work without key in ignition. And on the 556u bypass is that all the wiring i need or do i need to use the ring as well?
bs
Posted: May 21, 2018 at 8:24 PM / IP Logged Link to Post Post Reply Quote kreg357
The 556U is controlled by the R/S system to turn ON during R/S run time. A working key is placed inside the 556U, in a coil the reads the chip. The 556U's antenna wire is run up to the ignition cylinder and placed in a position to radiate the chip info sent to it from the 556U to the cars antenna, as if a key and chip were in the cylinder. So, yes, the 556U antenna must be used and located properly on the ignition cylinder.
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
