2008 Suzuki Swift Alarm Install, Australia
david_dinh
Posted: April 27, 2018 at 1:34 AM / IP Logged Link to Post Post Reply Quote david_dinh
Hi. I need the alarm wiring info for the 2008 Suzuki Swift Australia version. Thanks
tonanzith
Gold - Posts: 603
Posted: December 08, 2018 at 10:53 PM / IP Logged Link to Post Post Reply Quote tonanzith
2008 Suzuki Swift - North America
   Item
Wire Color
     Polarity
Wire Location
   12 Volts
   Red/Black
   Ignition Harness
   Second 12 Volts
   Orange
   Ignition Harness
   Ground
   (chassis ground)
            Starter
   Yellow (Smaller one)
   Ignition Harness
   Ignition
   Pink
   Ignition Harness
   Accessory
   Red/Black
   Ignition Harness
   Keysense
   Lt. Green
   At Key Switch or Drivers Kick Panel (green plug)
Power Lock
Gray/Green
   Underneath Passengers Side Dash
    Note - Power Lock: If not equiped with a KeyLess module, you will need to add an actuator in the drivers door
Power Unlock
Yellow/Green
    Note - Power Unlock: If not equiped with a KeyLess module, you will need to add an actuator in the drivers door
   Driver Unlock Motor
Dk. Blue
     Reverse
Drivers Kick Panel
   Factory Alarm Disarm
   Dk. Blue
   Drivers Kick Panel
Disarm No Unlock
Pink
   Drivers Kick Panel (Blue Plug)
    Note - Disarm No Unlock: Alarm Bypass Wire Pink. Breaking this wire with a relay will allow you to remote start without disarming.
   Parking Lights
Brown/White
At Dimmer Light Switch Harness
   Parking Lights -
   White
   At Parking Light Switch Harness
   Headlight
   Dk. Green/Black
   At Head Light Switch Harness
   Reverse Light
   Lt. Green/Black
   Drivers Kick Panel (yellow plug)
   Dome Light
   Dk. Green/White
   Drivers Kick Panel (Black Plug)
   Trunk/Hatch Pin
   Orange/Black
   Drivers Kick Panel
Hood Pin
Brown/Black
    Note - Hood Pin: OEM Hood Switch Brown/Black (+). Need to program the module for N.O. Hood Switch in level 3
   Tachometer
White
     4 Cyl
Drivers Side Firewall (gray plug)
Clutch Pedal
Violet
   At Clutch Switch Harness
    Note - Clutch Pedal: Connect the Remote Starter Wire directly on the Purple, for your Clutch Bypass instead of at the Ignition Switch.
   Fuel Pump
Large Lt. blue
Rear Defroster
Blue
8 Min. Neg
    Behind Rear Defrost Relay At Bottom Of Fuse Box
   Brake Wire
Brown
At Brake Switch or Drivers Kick Panel
   Parking Brake
   Brown
   Drivers Kick Panel (white plug)
   Horn Trigger
   Black or Black/White
   At Steering column
Wipers
2 Red Wires
   At Wiper Switch Harness
All I have.
Gary Sather
