Using a 2-Wire PATS Bypass on a 5-Wire Connector?
Simplemitch
Copper - Posts: 68
Posted: September 22, 2018 at 8:21 AM / IP Logged Link to Post Post Reply Quote Simplemitch
Hey all, this might be an easy (dumb) question, but I haven’t done a remote start in about 8 years.
I have an old CodeAlarm PC 7300 remote start that I’m thinking about putting in my 2007 Ford Focus. I bought a cheapy PATS bypass off Amazon (BANVIE Universal Immobilizer Transponder Bypass Module), which has an antenna loop for the key cylinder and a Positive/ Negative input. The code alarm has a 5-pin PATS/VATS harness with the following connections:
1. +12v
2. Ground
3. Ignition (+)
4. Starter Motor (+)
5. Active Out (-)
I’m assuming that key reading only takes place during cranking, so do you think Module Ground to Ground and Module Positive to Starter Motor (+) would work? If not, please point me in the right direction. Thanks.
Mitchell Whitney, Installer/technician
Mainstreet A/V
eguru
Copper - Posts: 340
Posted: September 22, 2018 at 8:34 AM / IP Logged Link to Post Post Reply Quote eguru
Use the Active Out(-) to activate the bypass.
You also need to drive the key-in-sense to +12V so you will need a small relay.
Simplemitch
Copper - Posts: 68
Posted: September 22, 2018 at 9:10 AM / IP Logged Link to Post Post Reply Quote Simplemitch
Thanks for the super fast reply! According to multiple wiring charts I’m looking at, the Key Sense is negative (red/black (-) at column harness). Can’t it be directly connected to the active out as is?
Mainstreet A/V
eguru
Copper - Posts: 340
Posted: September 22, 2018 at 3:42 PM / IP Logged Link to Post Post Reply Quote eguru
Whoops, sorry about the wrong polarity of key sense.
If its negative, then sure, just drive it with active out.
Regards
