Linkr LT1 with Fortin Evo One
earlr85944
Member - Posts: 6
Posted: October 16, 2018 at 12:07 PM / IP Logged Link to Post Post Reply Quote earlr85944
Hi, would anyone know how to troubleshoot my Omega LT1, its a new install on a 2017 Sonata, the evo one is working correctly with the factory remote and RF1 one way remote, i cant get the LT1 smartphone app to start the car??
Dazed and confused
iskidoo
Silver - Posts: 1,046
Posted: October 18, 2018 at 10:21 AM / IP Logged Link to Post Post Reply Quote iskidoo
I think these units have to be configured through a dealer. Is your unit already activated with service?
Steve G
earlr85944
Member - Posts: 6
Posted: October 18, 2018 at 12:06 PM / IP Logged Link to Post Post Reply Quote earlr85944
I was given the station code by the reseller and activated it
Dazed and confused
iskidoo
Posted: October 18, 2018 at 7:13 PM / IP Logged Link to Post Post Reply Quote iskidoo
I’ve never used either product but I found a YouTube video that shows a guy setting his up. His remote start unit is different than yours but perhaps it will lead you in the right direction. https://youtu.be/fJOlcraf3xY
Are you getting the yellow and green indicator lights in your Linkr as seen in the video? Maybe there is a setting on your remote start that needs to be changed to recognize the communication port between the 2 devices? I don’t have access to the Linkr install manual. If you upload it maybe I can help you figure it out.
Did you contact the reseller to see if they could offer any guidance?
Steve G
earlr85944
Member - Posts: 6
Posted: October 18, 2018 at 7:45 PM / IP Logged Link to Post Post Reply Quote earlr85944
I saw the video,,,no real help...red and green light are on,.i walked thru the install again with the manuf....possible defective unit....im gonna try and swap it out
Manual is here
https://fortin.ca/en/technology/rf_kits.html
Dazed and confused
earlr85944
Member - Posts: 6
Posted: October 18, 2018 at 7:48 PM / IP Logged Link to Post Post Reply Quote earlr85944
On the last tab change manufacturer to omega
Dazed and confused
iskidoo
Posted: October 18, 2018 at 8:14 PM / IP Logged Link to Post Post Reply Quote iskidoo
Was the whole learn routine successful?
TEP 8. LEARN THE TELEMATICS DEVICE TO THE EVO-ONE
In order to communicate with the remote starter, the MyCar must be learned to the EVO-ONE. 1 - Cycle the ignition to the ON position.
2 - The YELLOW LED on top of the EVO-ONE should come ON.
3 - Press and Hold the EVO-ONE push button for 5 seconds.
4 - The parking lights and the RED LED on the side of the EVO-ONE will turn ON.
5 - Release the push button.
6 - Press and Release the push button 5x times. Everytime the push button is pressed the parking lights
and the RED Led on the side of the EVO-ONE will blink.
7 - Then Press and Release the Brake pedal.
8 - Seconds later the RED LED on the side of the EVO-ONE will blink once to confirm that the MyCar ID has
been learned to the EVO-ONE.
9 - Cycle the vehicle’s ignition to the OFF position to Exit the EVO-ONE programming.
Steve G
earlr85944
Member - Posts: 6
Posted: October 18, 2018 at 10:27 PM / IP Logged Link to Post Post Reply Quote earlr85944
Yes
Dazed and confused
iskidoo
Posted: October 18, 2018 at 11:12 PM / IP Logged Link to Post Post Reply Quote iskidoo
I'd use a meter and test continuity between the 2 plug ends of the crossover harness for the blue wire and also the white wire. Seems like if everything else is working then maybe it's not making a good data connection. That's my last suggestion. Good luck. Let us know when you get this sorted out.
Steve G
earlr85944
Member - Posts: 6
Posted: October 18, 2018 at 11:31 PM / IP Logged Link to Post Post Reply Quote earlr85944
I will check, thx!
Dazed and confused
Wednesday, October 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
