Horn Honk, Avital 4105, 2016 Toyota Rav4
ricardoboston
Copper - Posts: 268
Posted: February 12, 2019 at 4:00 PM / IP Logged Link to Post Post Reply Quote ricardoboston
hi there I got a problem that I need to figure out how to activate the horn on 2016 Toyota RAV4 using Avital 4105 I need it to sound at least one time when the remote start is activated because I need to know if the car got the signal from the remote, any help really appreciate
guerra_85
Posted: February 12, 2019 at 4:15 PM / IP Logged Link to Post Post Reply Quote guerra_85
Which one is it???
Guerra_85
guerra_85
Posted: February 12, 2019 at 4:18 PM / IP Logged Link to Post Post Reply Quote guerra_85
Smart key, Hybrid o regular???
Guerra_85
motosaki
Member - Posts: 24
Posted: February 12, 2019 at 4:23 PM / IP Logged Link to Post Post Reply Quote motosaki
You should be able to program an aux wire for arm or lock after start and wire a relay to the horn wire I would think.
15yrs. in the industry. everything from simple deck installs, to remote starters, and full custom audio systems. I've Installed it all.
silvercivicsir
Copper - Posts: 416
Posted: February 13, 2019 at 4:47 PM / IP Logged Link to Post Post Reply Quote silvercivicsir
can't you just look to see if the "park lights" are on? if you can't see the park lights, I doubt you will hear the horn honk.
ricardoboston
Copper - Posts: 268
Posted: February 14, 2019 at 5:16 PM / IP Logged Link to Post Post Reply Quote ricardoboston
guerra_85            its a regular one thanks
ricardoboston
Copper - Posts: 268
Posted: February 14, 2019 at 5:34 PM / IP Logged Link to Post Post Reply Quote ricardoboston
I was thinking to use the factory alarm disarm on the horn wire I think it will work cause that wire will pulse negative signal before the car starts up ,what you guys think thanks
guerra_85
Posted: February 15, 2019 at 12:12 AM / IP Logged Link to Post Post Reply Quote guerra_85
Horn Honk, Avital 4105, 2016 Toyota Rav4 -- posted image.
Guerra_85
iskidoo
Silver - Posts: 1,048
Posted: February 15, 2019 at 10:05 PM / IP Logged Link to Post Post Reply Quote iskidoo
Should work. I’d use some alligator clips to temporarily connect the relay to insure it behaves the way you want it to before connecting it all up for good. Seems like you are on the right track.
Steve G
Monday, April 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
