Do Aftermarket Keyless Entry Modules Have Internal Relays?
shaunie61
Copper - Posts: 47
Posted: March 10, 2019 at 1:20 PM / IP Logged
Do aftermarket RKE systems usually have integral relays fitted?
Shaun
Platinum - Posts: 7,827
Posted: March 10, 2019 at 7:02 PM / IP Logged
Tough question to answer. Usually they do but I wouldn't generalize too much. Before I bought an inexpensive RKE system, I would want to check out their install guide to be sure. A decent one, like the Viper 211HV or the Avital 2101L, has internal door lock relays. The install guide for these systems is in the Downloads section. While I'm sure the terminology is different on the "imported" units, you are looking for signals like Lock Common, Lock Normally Open and Lock Normally Closed. Those are the actual lock relay pins.
shaunie61
Copper - Posts: 47
Posted: March 10, 2019 at 7:15 PM / IP Logged
Thanks,Kreg357.
I have bought the Toad RK30 which appears to be a good piece of kit from Scorpion.Excellent two button remotes.But the instructions are dire,despite it being a UK piece.Are you suggesting that the Lock normally open,Lock normally closed are the internal relay pins or the terminals to which I should connect external relays?
I'm wondering how I can test the output to the motors to see whether they are low or high current?
Shaun
Posted: March 10, 2019 at 8:10 PM / IP Logged
Below is the Viper 211 HV harness with wire labels. As mentioned, this unit has internal relays. It can be configured to support a wide variety of vehicles and door lock systems.   The best way to explain things is to compare this system to actual relays directly connected to door lock solenoids.   This site has door lock diagrams, here is a link : https://www.the12volt.com/doorlocks/how-to-determine-power-door-lock-types.asp This page gives a brief explanation of the lock type and a link to the relay wiring diagram used to interface that style of locks.   While I'm guessing that you don't need the entire Door Lock Study course, you can get additional info from this Directed TechTip 1041. Here is a link : https://www.the12volt.com/installbay/file.asp?ID=1213 Anyway, as you can see on the 211HV harness, they actually give the standard relay nomenclature numbers ( 30, 87 87A ) on the units wires. Relay is also important and can be gained with this link : https://www.the12volt.com/relays/spdt-and-spst-automotive-relays.asp
211HV
H1/1 RED (+) 12V CONSTANT POWER INPUT
H1/2 BLUE (-) 200 mA SECOND UNLOCK OUTPUT
H1/3 BLACK/WHITE-1 IN DOMELIGHT SUPER RELAY #87
H1/4 BLACK/WHITE OUT DOMELIGHT SUPER RELAY #30
H1/5 GREEN/BLACK LOCK #30 COMMON OUTPUT
H1/6 WHITE/BLACK LOCK #87A NORMALLY CLOSED
H1/7 VIOLET/BLACK LOCK #87 NORMALLY OPEN (INPUT)
H1/8 BLUE/BLACK UNLOCK #30 COMMON (OUTPUT)
H1/9 VIOLET UNLOCK #87 NORMALLY OPEN (INPUT)
H1/10 WHITE (+/-) PARKING LIGHT FLASH OUTPUT
H1/11 BLACK (-) CHASSIS GROUND INPUT
H1/12 BROWN (-) HORN HONK OUTPUT
H1/13 LT. GREEN/BLACK FACTORY ALARM DISARM
H1/14 WHITE/BLUE (-) 200 mA CHANNEL 3 VALIDITY OUTPUT
H1/15 YELLOW (+) SWITCHED IGNITION INPUT (ACCESSORY)
H1/16 ORANGE (-) 500 mA GROUND-WHEN-ARMED OUTPUT
H1/17 BROWN/BLACK UNLOCK #87A NORMALLY CLOSED
H1/18 RED/WHITE (-) OUTPUT OF CHANNEL 2
If you could post the wire harness and info on your system, that would
help determine if it had internal relays. Also knowing the current truck
lock wiring would help.
shaunie61
Copper - Posts: 47
Posted: March 11, 2019 at 1:22 PM / IP Logged
This is all the wiring information I have from the RKE manufacturer: Please note this is keyless entry only with no alarm or immobiliser etc.
Grey/Red       =      Lock Common
Red/Yellow     =      Lock Normally Open
Grey/Yellow    =      Lock Normally Closed
Red/Black      =      Unlock Normally Open
Blue/Red       =      Unlock Common
Red Permanent Live
Black Earth
Orange Ignition switch supply
Black/white and Black/Green Positive indicator(turn signal)feeds
Brown/white window close or headlight flasher (relay required).
As far as I can establish, the van has a four wire reverse polarity setup with a three position switch on the dash. This is wired direct to the motors without any relays.Again,as far as I can establish....
Shaun
Posted: March 12, 2019 at 9:31 AM / IP Logged
A three position switch with up for lock, down for unlock and a neutral center rest position?
Your RK30 system has internal door lock relays? What is the input fuse value?
shaunie61
Copper - Posts: 47
Posted: March 12, 2019 at 4:38 PM / IP Logged
Yes the three position switch is as you describe it.
The fuse value to the RK30 is 15amps
Shaun
Posted: March 12, 2019 at 11:12 PM / IP Logged
Take a look at the wire connections to that switch. If it is just three wires, 12V constant in the center and output legs for lock and unlock at top and bottom, it should be easy to have your RK30 supply the needed +12V to the same output terminals.
shaunie61
Copper - Posts: 47
Posted: March 13, 2019 at 9:46 AM / IP Logged
The switch has a total of six wires,two of which are for illumination, so we can discount them.
The remainder are Red, for Permanent live; black for ground (I tested these to check) These are in the center of the switch
Blue and blue for the lock and unlock legs .
While the wiring was accessible I tried all the wiring diagrams again (positive trigger locking and negative trigger locking),and the diagram showing the wiring for 'additional motor locking' (presumably an aftermarket installation?).This was the only one that moved the motors at all.
It seemed to be very,very weak compared to directly connected via the switch,as if the motors arent getting enough current.
Shaun
shaunie61
Copper - Posts: 47
Posted: March 19, 2019 at 1:31 PM / IP Logged
On the basis that I cant find a definitive reply, I have purchased pair of relays with diodes fitted to try and improve the current supply to the motors.
Eventually I will connect it and see what happens. At last the diodes will protect the transistors within the RKE unit should a spike occur...
Shaun
