2006 Buick Rendezvous Remote Starter Ignition Wire Clarification
dustint91
Posted: March 18, 2019 at 10:56 AM / IP Logged Link to Post Post Reply Quote dustint91
I am installing a Compustar CS800s with a Fortin INT-SL+ in my '06 Rendezvous.
All of the info I can find online just says that the pink ignition wire from the Fortin unit should go to the pink ignition wire in the ignition harness of the car. The issue is, I do not know which pink wire to use. I see 3 pink wires in the ignition harness. Does anyone know what pin the wire is on the ignition harness connector? Or an other way to identify it? Is there a way for me to test the voltage at different key positions to determine which one is the right one? Thank you for any help.
geepherder
Platinum - Posts: 3,668
Posted: March 18, 2019 at 11:58 AM / IP Logged Link to Post Post Reply Quote geepherder
The correct wire will show 12 volts with the key in both the Run and Start positions.
dustint91
Posted: March 18, 2019 at 12:22 PM / IP Logged Link to Post Post Reply Quote dustint91
Will only one of the pink one's do that? I can't recall if I tested for that on all of them, but I feel like I had at least 2 that showed that. I will check them again when I get home tonight.
dustint91
Posted: March 18, 2019 at 12:24 PM / IP Logged Link to Post Post Reply Quote dustint91
Also, the Compustar has a blue wire that you can decide it's function with a jumper. Default function is Ignition 2. I have not connected this anywhere. Do I need this on my car? If so, where does it connect and do I need to move the jumper?
geepherder
Posted: March 18, 2019 at 1:59 PM / IP Logged Link to Post Post Reply Quote geepherder
I can't tell for sure if only one will test ignition. They might be connected in parallel. Your Fortin install manual should say what connections are required.
I'm not familiar with Compustar, perhaps someone else can answer that.
iskidoo
Silver - Posts: 1,046
Posted: March 18, 2019 at 5:24 PM / IP Logged Link to Post Post Reply Quote iskidoo
2006 Buick Rendezvous Remote Starter Ignition Wire Clarification -- posted image.
Steve G
iskidoo
Posted: March 18, 2019 at 5:27 PM / IP Logged Link to Post Post Reply Quote iskidoo
Yes leave jumper set to ignition 2 and connect it to the green wire shown in photo in my previous post.
Steve G
dustint91
Posted: March 19, 2019 at 12:55 PM / IP Logged Link to Post Post Reply Quote dustint91
Wow nice pictures! I could have used that a few days ago haha. I ended up getting it sorted out last night before seeing this. Took lots of digging online and reading a billion posts. Though seeing these pictures does give me some reassurance that I got the right wires since I did it just as your pictures show. Thank you!
iskidoo
Posted: March 21, 2019 at 10:23 PM / IP Logged Link to Post Post Reply Quote iskidoo
iskidoo
Posted: March 21, 2019 at 10:47 PM / IP Logged Link to Post Post Reply Quote iskidoo
Saturday, October 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
