If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
Sunday, March 29, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
Okay, so I found out I have a negative triggered clutch switch. How can I integrate it into the relay in the picture I attached? I tried the diagrams provided, but it doesn’t run to ground, and I need the current figuration to get the vehicle to start.
