remote start problem
terryuk73
Member - Posts: 13
Posted: June 07, 2003 at 9:33 AM / IP Logged
I'm in the process of installing a clifford intellistart on my MR2, the car will crank, but not actually start, anyone have any experience with this vehicle, as I've run out of ideas
thanks
Terry
Moderator - Posts: 12,488
Posted: June 07, 2003 at 9:38 AM / IP Logged
You are probably missing an IGN wire. What year MR2 do you have ?
terryuk73
Member - Posts: 13
Posted: June 07, 2003 at 9:39 AM / IP Logged
1991
jrilla
Gold - Posts: 1,498
Posted: June 07, 2003 at 9:49 AM / IP Logged
You may have your Ignition and Accessory wires mixed up. Test the Ignition and Accessory wires with a DMM to see when each gets power during the remote start process.
I am not familiar with that alarm, but you should make sure you have followed all of the steps in the manual regarding learning the tach signal.
J Rilla
Owner/Installer
jrilla
Gold - Posts: 1,498
Posted: June 07, 2003 at 9:56 AM / IP Logged
12V BLACK/ red - white
Starter red
Ignition BLACK / YELLOW
2nd Ignition BLACK/ orange
Accessory blue/red
Tachometer BLACK/ white check connector [1]
You need to grab all of these wires
J Rilla
Owner/Installer
terryuk73
Member - Posts: 13
Posted: June 07, 2003 at 10:01 AM / IP Logged
2nd ignition?
Posted: June 07, 2003 at 10:06 AM / IP Logged
Second Ignition relay
This controls certain electrical operations on the car like FI, transmissions computers, ABS, etc. This needs to be energized otherwise the car will not start or it will run badly after start.
terryuk73
Member - Posts: 13
Posted: June 07, 2003 at 10:17 AM / IP Logged
so would i just connect the ignition line (WHITE/ brown) to both of these ignition lines on the car?
http://www.directed.com/guides/manuals/ig/clifford/intellistart_install.pdf
Posted: June 07, 2003 at 11:13 AM / IP Logged
No you must use a relay for the 2nd IGN wire. What you can do is use the 1st IGN wire to engage a relay to add power to the 2nd IGN wire if you do not have a ground out when running wire.
terryuk73
Member - Posts: 13
Posted: June 08, 2003 at 9:07 AM / IP Logged
thanks guys it worked
terry
Tuesday, November 11, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
