Python Window Roll Up Aux - Relay or Module?
mckee1710
Member - Posts: 10
Posted: October 21, 2019 at 7:15 PM / IP Logged Link to Post Post Reply Quote mckee1710
Researching to install Python 413 remote start/keyless entry on my 97 Chevy K1500. Would like to utilize the aux/trunk latch to roll my windows up, as I often leave them cracked. The aux is the typical low amp negative output that lasts for the duration of the transmission, per the install sheet. Can I just wire this to two SPST relays on each of the window up wires between the switch and the window motors? Or do I need to use a dedicated window module like the DEI 529T?
iskidoo
Silver - Posts: 1,046
Posted: October 22, 2019 at 8:10 AM / IP Logged Link to Post Post Reply Quote iskidoo
Most recommend the module for the limiter circuit that is built in.
https://www.the12volt.com/installbay/forum_posts.asp?tid=22460
Steve G
mckee1710
Member - Posts: 10
Posted: October 22, 2019 at 11:18 AM / IP Logged Link to Post Post Reply Quote mckee1710
Makes sense, thanks!
Monday, December 1, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
