If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
Saturday, May 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
91 Jeep Cherokee Wires CN1 Main Harness
Constant 12V+ Red Pin 1 Red
Parking Lights Blue/Red Pin 2 Green/White
Constant 12V+ Red Pin 3 Red/White
Accessory Purple Pin 4 White
No second ignition needed Pin 5 Blue
Starter Yellow/Green Pin 6 Yellow
Ignition Blue Pin 7 Green
To Ground Pin 8 Black
Connector 3 (CN3)
Using connector on CN-1 Main Harness Pin 1 Green/White
Door Lock, using connector on CN-4 Relay Harness Pin 2 Blue/Green
Door Unlock Using Connector on CN-4 Harness Pin 3 Blue
For Transponder/Bypass module Pin 4 Black
Factory Arm Pin 5 Orange
Factory Disarm Green/Orange (-) Pin 6 Orange/White
Horn Wire* Black (-) Pin 7 White
Hood Closure (-) Pin 8 Gray/Black
Brake Switch White Pin 9 Light Blue/White
For use by original factory remote Pin 10 Red/White
For use by original factory remote Pin 11 Red
Tach Gray/Lt Blue or (Green) Pin 12 Yellow/Black
CN-4
Pin 1 Not used
Trunk unlocks with all doors, no auto release Pin 2 Violet/White
No using prioriy unlock Pin 3 Orange/Black –
Door Unlock Pink/Purple Pin 4 Blue
Door Lock Orange/Purple Pin 5 Blue/Black
Pin 6 Not used
Head Lamp Brown/Black Headlights vs park lights come on
Door Trigger Yellow (-) For Alarms and/or dome light supervision
