If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
Sunday, March 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
*I apologize for the upside down image
I have even played around with the pulse settings to see if it would make a difference. The purple wire on the obd2 for passlock bypass is wired of course. Just curious if anyone has any ideas on what the issue might could be. Thank you!
I'm guessing it powers a relay that then sends power to the starter. Not a single FB page or forum online showed which wire on a 2002 diesel was the starter wire, nor the install guide from Firstech. This is not your fault of course, I just figured it would have been more common than it is I guess. Rant over lol.
Yes, my J1820 orange wire going to the purple wire on the OBDII is in fact from the M4 plug. My apologies, I was getting the order of the connectors mixed up.
From the DC3 to truck I have the current connections,
M1 Connector:
Red (constant) to Red (constant) (may end up tying in the Red with white stripe)
Pink (IGN1) to Pink (IGN1)
Pink/white (IGN2) to White (IGN2)
Orange (ACC1) to Orange (ACC1)
Purple (Starter) to Yellow (small awg Starter)
White (Parking lights) to Brown (on light blue plug on BCM)
Black (Ground) to Dash stud
M2 Connector:
White/Black with Black Dot (Horn) to Black (on brown plug on BCM)
M3 Connector:
Brown with Silver Dot (+ Brake Input) to White (brake switch above pedal)
Purple/White with Silver Dot (Tach Input) to White (on back of cluster)
Hood wire not currently wired, was planning to install switch after R/S was functioning.
M4 Connector:
Orange (J1820) to Purple (OBDII)
Let me know if this looks correct to you.
I bought my FT-DC3-LC without any remotes and planned to only use the factory key fob so I am unsure if another remote paired will work.
For the programming sequences, I am referring to these located here on pages 6 and 7.
