How do I wire a switch?
gizmosrealm1
Member - Posts: 11
Posted: June 11, 2003 at 3:26 PM / IP Logged
Hey guys.  I'm trying to wire power door locks into my '92 civic.  I'm using 2 relays, 2 actuators, and a momentary switch.  I've checked out the diagrams here on this site, but all seem to use an alarm as part the circuit.  I would like to wire the door locks up without using an alarm since I don't have one right now.  So, how do I wire this together to run off just a switch?  Can I add an alarm w/ keyless entry in the future to this?  Thanks in advance for any help.
gizmosrealm1
Member - Posts: 11
Posted: June 11, 2003 at 3:33 PM / IP Logged
to help clarify, the actuators I have have 2 wires.  They need negative on one and positive on the other to push.  The polarity needs to then be reversed (ie-negative to positive and positive to negative) to pull.  The actuators are made by IMPACT if that helps.
xetmes
Silver - Posts: 586
Posted: June 11, 2003 at 3:42 PM / IP Logged
just use the set-up from this site, but instead of the alarm input use the switch, i rocker switch is the easiest to hook up this way.
xetmes
Silver - Posts: 586
Posted: June 11, 2003 at 3:47 PM / IP Logged
ohh the reason i say to do that is so that if you want to add an alarm in the future, you can just hook it up to the already existing relays
jrilla
Gold - Posts: 1,498
Posted: June 11, 2003 at 3:57 PM / IP Logged
Just like xetmes said, use forth diagram down from the top of the page that this link takes you to:
Relay Page
You just need to connect the two outside pins from the switch to the either of the pins on the relay that are currently connected to the alarm output. Then the center pin on the switch should would go to chasis ground.
J Rilla
Owner/Installer
gizmosrealm1
Member - Posts: 11
Posted: June 11, 2003 at 5:55 PM / IP Logged
Thanks for the info...one more question though, should I be using the 5-wire hookup or the reverse polarity hookup?  I was thinking reverse polarity.
rudbwoy69camaro
Silver - Posts: 350
Posted: June 11, 2003 at 6:28 PM / IP Logged
Reverse polarity, it worked for me...
My switch issue
I had to put one on my '91 Integra, but it wasn't like the wiring diagrams posted on here.  Lucky I have a car alarm and started probing around with a ground and hit the right pins for lock and unlock and tapped in.  I'll go check it out...
How do I wire a switch? -- posted image.
gizmosrealm1
Member - Posts: 11
Posted: June 11, 2003 at 6:34 PM / IP Logged
Thanks for all the help, I'll go try it out.  Ignore my earlier post, JRILLA already said use the 4th on down in the post prior to it.  My bad ;-)
gizmosrealm1
Member - Posts: 11
Posted: June 12, 2003 at 3:49 PM / IP Logged
Thanks everybody for the help, I got it all wired up and it works great!!
xetmes
Silver - Posts: 586
Posted: June 12, 2003 at 4:40 PM / IP Logged
cool  How do I wire a switch? -- posted image.
Saturday, December 27, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
