2007 Acura MDX, Power Tail Gate Opener
hiltonle1975
Posted: May 10, 2024 at 11:17 PM / IP Logged Link to Post Post Reply Quote hiltonle1975
I have 2007 acura mdx I install remote start now I have a problem with wiring relay for power tail gate opener
Please help !
Platinum - Posts: 7,828
Posted: May 11, 2024 at 9:49 AM / IP Logged Link to Post Post Reply Quote kreg357
At the dash fuse box locate the Green 21 Pin connector (upper left).   There will be a White wire and a Brown wire directly across from each other at Pins 6 and 18.
Relay wiring :
Relay Pim 85 to R/S (-) Trunk Release output
Relay Pin 86 to +12V constant
Relay Pin 87 to White wire
Relay Pin 30 to Brown wire
Relay Pin 87A not used - insulate
hiltonle1975
Posted: May 11, 2024 at 10:07 PM / IP Logged Link to Post Post Reply Quote hiltonle1975
Thank you so much for the information
