Keep blowing fuse help!
1gta2c
Member - Posts: 22
Posted: June 15, 2003 at 6:05 PM / IP Logged
  I  have put in my alarm and I keep blowing the fuse. All the options on the alarm work fine when I test them.Automatic doors , trunk, dome light, shock sensor, and hood pin. I will drive the car to the store 10 minits  away and all is fine. I will drive for an hour and all is fine. I stop and start the car and the fuse will blow with no rym or reason. The ground is good and the and the must power to run any of these options is the power trunk and I put a 15 amp fuse on this to be sure and it blows the 30amp main fuse. I contacted the manufacter of the alarm and they didn't tell me anything that I didnt try. Any help on this would be greatly apprec...Keep blowing fuse help! -- posted image.
the12volt
Administrator - Posts: 3,957
Posted: June 15, 2003 at 6:20 PM / IP Logged
What alarm is this and what year, make, & model vehicle do you have?
Keep blowing fuse help! -- posted image. the12volt • Support the12volt.com
1gta2c
Member - Posts: 22
Posted: June 15, 2003 at 6:24 PM / IP Logged
 I have the mannix sm700. It is in a 1991 pontiac trans am gta with no factory alarm. Thier website is www.mannixusa.com for more info. thanx
the12volt
Posted: June 15, 2003 at 6:32 PM / IP Logged
Does the fuse blow only when you start the vehicle or does it do it at other times as well?
1gta2c
Member - Posts: 22
Posted: June 15, 2003 at 6:40 PM / IP Logged
 No, the remote start option is not inst... it is standerd transmission and I didn't want this function. I use it as a traditional alarm. I don't know when it blows, it might be today or two days from now. I cant track it and I have looked and an electrition has looked at it all and all seems good???
the12volt
Posted: June 15, 2003 at 6:51 PM / IP Logged
That's not what I was implying. I was asking if the fuse blows when you start the vehicle with the key or at other times as well. If it's an intermittent problem, then it's likely you have a poorly insulated connection on one or more leads, specifically the main power lead(s) or any 12V+ output lead from the alarm or relays that you may have added. You'll need to comb through your connections and check each one carefully until you find it unless you can narrow it down more than you have already.
1gta2c
Member - Posts: 22
Posted: June 15, 2003 at 7:39 PM / IP Logged
I  only have one 12v+ lead out from the alarm. One relay for the doors,pkg. lihgts and engine kill. I dont know exactly when it blows, maybe when I start it, when I drive or when I stop the car.It is VARY inconsistant in the timing of when it blows that is why I cant track it.I saudered all the connections to  encure this wont happen. Could it be a bad relay and if so how do you check???
draasch
Gold - Posts: 2,172
Posted: June 15, 2003 at 7:43 PM / IP Logged
are you talking about the main fuse for the alarm????
where did you get your power from???
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
1gta2c
Member - Posts: 22
Posted: June 15, 2003 at 7:48 PM / IP Logged
 From a consistant 12v+ power source in the car. I was going to take it right from the battery but I was advised it wouldnt make a difference.
the12volt
Posted: June 15, 2003 at 8:00 PM / IP Logged
If the problem doesn't occur with any regularity, and being that it's a new install, its unlikely that you have a bad relay. Problems like this are usually caused by wire exposed at any one of your connections coming into contact with a ground or a chafed lead near a sharp piece of metal. I'd look for any sharp pieces of metal near the alarm harness and main power wire if you are sure all of your connections are well insulated. Also check any leads you may have run to other components such as the siren, sensors, lights, etc.
Page of 4
Wednesday, December 24, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
