remote start on a 2003 ranger
SoundImage
Copper - Posts: 75
Posted: June 18, 2003 at 2:30 PM / IP Logged
I've installed a hornet 554t on a 2003 ranger.  The ranger in a manual trans.  I need to bypass the clutch sensor but it has about 6 or 7 wires on it.  i found a wire that reads 5.50 ohms when the clutch is depressed.  after the vehicle starts it jumps to 56 ohms, then starts dropping slowly till it hits 18.1.  I need to know how to bypass this to start the truck.  Any info is appreciated.
Moderator - Posts: 12,488
Posted: June 18, 2003 at 2:43 PM / IP Logged
Here is how you test for the clutch wire:
SoundImage
Copper - Posts: 75
Posted: June 18, 2003 at 3:09 PM / IP Logged
If i apply a negative to the wire the truck still won't start i think it needs to see 5.50 ohms to start.
Sunday, November 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
