Sunroof and free AUX channel.
Manokat
Member - Posts: 12
Posted: July 09, 2003 at 1:18 PM / IP Logged
A dealer refused to do the job because the roof has "tilting". Said that it's hard to do the job even with a window module.
Please help verify that this really can NOT be done. The following is the schematic for the sunroof of Protege5.
http://216.254.182.194/12volt.jpg
I have 4 AUX channels free. All i need is to open and close the roof with my remote.
Initially i was thinking of doing it my self but when i tried to buy a window module for this, the dealer said that it was not possible to control a roof that has a tilting even with a window module.
Please help verify this by looking at the schematic.
djfearny2
Silver - Posts: 810
Posted: July 09, 2003 at 1:32 PM / IP Logged
what kind of car and is the roof sunroof whatever controled by electric. get a good dei windows mod and it should be able to be done. with tilting what ever,,,
let me see so this sunroof vents as well as slides all the way back . ???? email me with info or help.
Jon
Installer/Help Technician
---coral springs florida---
cpgoose
Gold - Posts: 1,098
Posted: July 09, 2003 at 2:45 PM / IP Logged
Yea, I don't see why you can't do it either. Get a DEI 529t, those are the sunroofs modules. You should be able to hook up OPEN to one channel, and CLOSE to another. By the way, what alarm do you have that has 4 extra channels? that's cool :-)
Q: What's the best nation in the world?
A: Donation!     Donate to the12volt.com
Manokat
Member - Posts: 12
Posted: July 11, 2003 at 9:24 AM / IP Logged
To answer your questions "djfearny2", my car is a Mazda Protege5. It has a sunroof that is electronically controlled, check the schematic on my previous post.
As for "cpgoose" question relating to the alarm, I have the Autopage RS-850LCD.
My car is a hatch that is why i do not use channel 2 of the alarm which is the trunk release. The alarm does have channel 4,  5, 6 available for use. They can be programmed to be momentary, latched, latched ignition reset, and pulse, and timer 0.9 to 2 minutes.
Now I have another question, is it OK not to use sunroof module?
I am thinking of using channel 4 and a relay for sunroof opening and program it to be active for about 5 seconds and channel 5 and another relay for sunroof closing and program it to be active for about 5 seconds.  I have checked the roof will fully open if i hold the switch for 5 seconds and the same thing for closing.
What i am worried though is that if the time is not right the motor maybe supplied voltage more then it should. Wil my motor be damage?
rudbwoy69camaro
Silver - Posts: 350
Posted: July 14, 2003 at 5:11 PM / IP Logged
I have a relay to the sunroof of my integra, and from there-channel 2 of the RS3 close only though.  Works fine, relays and your channels(two, like you said-one for open, one for close)should do it.
cpgoose
Gold - Posts: 1,098
Posted: July 15, 2003 at 6:24 AM / IP Logged
True, you can do it with a relay...just be careful because like you said......you can burn out the motor if the timing isn't right. You'll get that rrrrrrrr. That's why the sunroof modules are cool, because they know when to stop.
Big Purds
Silver - Posts: 574
Posted: July 16, 2003 at 6:07 AM / IP Logged
one of the first things I ever did a long time ago was help a friend of mine hook his VW sunroof up to his Viper 500HF...the exact details arent that clear right now, cuz I was just learning more than anything at that point, and for some reason cant remember exactly what we did...
if you want me to ask him, I can get ahold of him tomorrow and get back to you, but it worked very well and we didnt have any problems with it...
