Mannix
Patrick-C
Posted: July 09, 2003 at 3:35 PM / IP Logged
Has anyone heard of Mannix car alarms. I have been to there web site, and I was just wondering if anyone has installed, and used one of these units.
mainormoscoso
Member - Posts: 41
Posted: July 10, 2003 at 8:06 PM / IP Logged
they work realy well, I got 2 alarms 2 way with lcd remote start and I instaled it in a 97 eclipse manual transmision and in a 2002 envoy.  they got realy good range on the remote.
Patrick-C
Posted: July 10, 2003 at 9:12 PM / IP Logged
mainormoscoso
Cool,
Did you have any problems with the installation? I am installing in a 2002 Cavalier and am struggling a bit locating all the connections. If you have any suggestions I will be a sponge
Patrick
Platinum - Posts: 12,488
Posted: July 11, 2003 at 12:35 AM / IP Logged
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
| SECOND ACCESSORY|brown               |+  |ignition harness            |
|       POWER LOCK|lt. blue            |*2 |either kick panel           |
|     POWER UNLOCK|white               |*2 |either kick panel           |
|       LOCK MOTOR|gray                |   |drivers kick panel          |
|     UNLOCK MOTOR|tan                 |   |drivers kick panel          |
|    DISARM DEFEAT|tan                 |   |passengers kick panel       |
| PARKING LIGHTS +|brown               |   |harness to rear, dkp        |
|       HEADLIGHTS|dk. blue            |-  |headlight switch            |
|     DOOR TRIGGER|grn/blk & lt. blue  |-  |*3                          |
|  TRUNK/HATCH PIN|black               |-  |trunk light                 |
|TRNK/HTCH RELEASE|BLACK/ white         |+  |BCM *4                      |
|       TACHOMETER|PURPLE / white        |   |engine harness *1           |
|       BRAKE WIRE|white               |+  |stop light switch           |
|     HORN TRIGGER|black               |-  |steering column             |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|dk. blue - brown    |A  |LF window motor in door     |
|  RF WINDOW UP/DN|lt. blue - tan      |A  |drivers kick panel          |
|  LR WINDOW UP/DN|dk. green - purple  |A  |drivers kick panel          |
|  RR WINDOW UP/DN|lt. green - purple  |A  |drivers kick panel          |
Notes:
NOTE: This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with. Use DEI part 555t or 555L.  *1 The engine harness is found next to the battery, below the radiator hose, just above the transaxle.   *2 Non keyless cars, locks are 5wi (type C) and they are mastered from the passenger side switch. Keyless cars, locks are positive trigger (type A). Also found at BCM.  *3 The GREEN/ black is located in the lower drivers kick panel. It catches the drivers door only. The light blue is located in the lower passenger kick panel, and catches the passenger door(s). Tap both wires and diode isolate each. Also found at BCM.  *4 The BCM is located to the left of the steering column above the kick panel.
asjeep
Member - Posts: 22
Posted: July 11, 2003 at 10:36 AM / IP Logged
where did you get your mannix? how much did it run looking at one on ebay for about 150.00 with shipping but only has 1 remote
2001 jeep wrangler se
slipnfall
Member - Posts: 36
Posted: July 11, 2003 at 1:24 PM / IP Logged
Hi Patrick,
I just purchassed a mannix alarm system from Ebay for ~$140USD. I'm quite eager to get it home and start installing it. FWIW, this is my first install I'v attempted and am actually looking forward to it. I dug around on the net a bit and I can't find much info on this Mannix company(other than the corp. website and online stores). Not much in newsnet either. Anyways, I hope to start on this within the next two weeks or so, provided I can get my power door locks working(module fried).
Please keep us posted on how things go - if there's any problems I'd like to hear about them ahead of time!
BTW, what vehicle is this going into? Putting on on a '90 Accord EX (not worth much but lotsa vandalism in this area). One problem I see already is the neutral switch - don't know if I have one.
Regards,
-Jamie
Patrick-C
Posted: July 17, 2003 at 4:23 PM / IP Logged
slipnfall
I just got finished installing the unit in my 2002 Cavalier. The installation, went without a hitch, except!
I get three(3) beeps from the system the documentation says it should be only one(1) unless a door is open. All doors are shut. Not sure what the problem here is could be that I missed someting. Also I don't get a signal reading on my remote that tells me the signal stength.
If someone could give me a little insite I would be greatful.
Other than the items above the unit works GREAT!
Patrick
mainormoscoso
Member - Posts: 41
Posted: July 17, 2003 at 10:09 PM / IP Logged
I had the same problem 3 beeps when arming when I installed my in the 97 eclipse and the problem was the dome delay circuit of the car the alarm was reading that the door was open, also you have to put a relay when conecting the dome supervision of the alarm and the alarm imput wire or the car will start once and then if you shut it down it will not remote start again, the diagram for  that it's with the manual of the alarm.
Good Luck
