Help with 1999 Accord alarm
Dubs420
Member - Posts: 10
Posted: August 04, 2003 at 7:08 PM / IP Logged
first off my car is a 1999 honda accord lx 4dr
i purcased a alpha guard alarm off ebay with a alarm/ keyless entry / remote start.....
i cant seem to find the locations for these wires since my diagram that the alarm came with uses diffrent phrases suck as door trigger and door switch.....
here are some diagrams i drew "sorry for the mspaint action"
question #1i have two parking light + wires from the alarm where do i hook these up
question #2 where do i find the oil light wire?
question #33what the hell is the starter and lock key things?
question #4 how do i hook my keyless entry wires up?Help with 1999 Accord alarm -- posted image.Help with 1999 Accord alarm -- posted image.
Dubs420
Member - Posts: 10
Posted: August 04, 2003 at 7:10 PM / IP Logged
profuse007
Gold - Posts: 2,015
Posted: August 05, 2003 at 7:41 AM / IP Logged
#1- this might be selectable polarities, accord have both polarity (+,-).
- if this not selectable polarities but have two wires, then one of the wire is the input of either polarity and the other one is output of that polarity inputed. on the diagram does it say 30 and 87 ????
#2- no clue to what oil lights are. need more info.
#3- starter is for RS that goes to the starter.
-lock keys- lock maybe since there are no other lock wire. but no unlock wire on the diagram????
#4- same as #3
Houston,TX
profuse007
Gold - Posts: 2,015
Posted: August 05, 2003 at 7:45 AM / IP Logged
lookin at teh second diagram, the down and up seems to be unlock and lock?????
no clue on the red and yellow
what condition is this alarm? new or used?
Houston,TX
Dubs420
Member - Posts: 10
Posted: August 05, 2003 at 11:14 AM / IP Logged
its brand new
Dubs420
Member - Posts: 10
Posted: August 05, 2003 at 11:34 AM / IP Logged
i cant find out where to hook up the last few wires
http://mywebpages.comcast.net/dubs420/2.jpg
here is a diagram of my problem
Platinum - Posts: 12,488
Posted: August 05, 2003 at 1:01 PM / IP Logged
What wires did you need help with ? I'm trying to follow your last post, but the diagram did not have which wires you needed help with. Also, it you can get a wiring diagram of the alarm and scan it onto this site, that would benefit anyone trying to help you.
Dubs420
Member - Posts: 10
Posted: August 05, 2003 at 2:40 PM / IP Logged
after spend most of the night in the backyard these are the last few wires that I cant find......
#1i cant find the oil light wire
#2 i cant find the wire that tells the car/alarm the doors are open
#3cant figure out how to wire the remote start all i have is a diagram looks exactly like the one i drew
http://mywebpages.comcast.net/dubs420/2.JPG
Dubs420
Member - Posts: 10
Posted: August 05, 2003 at 4:34 PM / IP Logged
Posted: August 06, 2003 at 12:39 AM / IP Logged
1. Why do you need to find the OIL LIGHT wire for this system ? What does the OIL LIGHT have to do with an alarm or RS installation ?
2. DOOR TRIGGER           BLACK/ white         |-  |     passenger fuse box In a green 4 pin connector. You do not need to hook up the (+) door pin switch wire from the alarm anywhere. Tape it off and DO NOT USE
3. You will need to hook up the following wires in order for the remote start to work properly ( Also, you have to bypass the Immobilizer key from Honda )
  • I                 12V     |white               |+  |ignition harness
    |          STARTER|BLACK/ white *1      |+  |ignition harness
    |         IGNITION|BLACK / YELLOW        |+  |ignition harness
    |  SECOND IGNITION|yellow              |+  |ignition harness
    |        ACCESSORY|WHITE/ black         |+  |ignition harness
