Viper remote start learning problem
kenhamr
Member - Posts: 9
Posted: August 07, 2003 at 3:37 PM / IP Logged
Hi Ihave problem whit tach learning. It's a chevy full size 1990 diesel. I don't have any tach so I have connected the wire to +12 v.
When I start the car and press the valet switch to to learn the signal it's not light in the LED
Thanks Ken
Ken
ViperATC5
Copper - Posts: 202
Posted: August 07, 2003 at 5:00 PM / IP Logged
You are not going to be able to learn tach on a DC 12V signal. Tach is a fluctuating AC signal that increases as the vehicles RPMs increase.
Use the Tach wire as indicated below or change the unit to use voltage sensing.
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|red                 |+ |ignition harness            |
|          STARTER|yellow or purple    |+ |ignition harness            |
|        IGNITION|pink               |+ |ignition harness            |
|        ACCESSORY|orange              |+ |ignition harness            |
|       POWER LOCK|lt. blue            |+ |driver door harness        |
|     POWER UNLOCK|blk/white           |+ |driver door harness        |
| PARKING LIGHTS +|brown               |   |switch or fuse panel        |
|       HEADLIGHTS|yellow              |+ |at switch                   |
|     DOOR TRIGGER|white               |- |under dash area             |
|       TACHOMETER|PURPLE / white        |   |dist. or ECM *1             |
|       BRAKE WIRE|white               |+ |at brake pedal switch       |
|     HORN TRIGGER|black               |- |at column                   |
|           WIPERS|purple              |   |steering column             |
| LF WINDOW UP/DN|dk. blue - brown    |A |at drivers door switch      |
| RF WINDOW UP/DN|blu/wht - tan       |A |                            |
| LR WINDOW UP/DN|                    |   |                            |
| RR WINDOW UP/DN|                    |   |                            |
Notes:
*1 4-wire harness exiting back of distributor heading towards pass. side or pull glove box and ECM is silver box with two plugs. Diesel wait to start wire is dk. blue (+) located at the instrument cluster.
Himself
Member - Posts: 36
Posted: August 07, 2003 at 6:08 PM / IP Logged
You might also want to progarm your remote start to wait before start to allow for your glow plug to have affect.
What?
