529T in an unusual application
MTXpert
Posted: August 16, 2003 at 11:22 AM / IP Logged
I want to use a 529T to open and close my electric cutout on my car (DC motor that opens and closes allowing full open exhaust or regular exhaust) automatically off of a full throttle 12V+ switch.
This is a regular 12VDC motor equivilant to a power window motor. I'm looking at the instructions and I came up with the following:
Green to positive side of motor
Blue to negative side of motor
Red - 12V+
Black - 12V-
And a relay hooked up :
85 ground
86 - 12v+ trigger from full throttle switch
30 ground
87 Orange
87A ORANGE / Black
This will cause the rest at ground on side A to close the cutouts then stop, 12V+ from full throttle switch will open the cutouts and keep them open until 12V+ is removed while not at full throttle. This won't be active all the time just when I close a switch allowing the 12v+ through to the relay.
Do I have this right?
Mike Bambic A.K.A. "The Bambinator"
MTXpert
Posted: August 16, 2003 at 4:59 PM / IP Logged
Well, that didn't work. I'm not even getting a test light to light for a second when it's hooked up that way...
Any ideas?
Mike
