Brake switch hook up?
12volttrix's
Member - Posts: 12
Posted: August 31, 2003 at 2:56 PM / IP Logged
I am installing a Code Alarm remote start on a 1997 Pontiac TransAm and am having trouble finding the right wire for the brake switch. The database says that it is a LT Blue or White wire off the switch above the brake pedal. I have a Pink and also a Brown. Is there a way to test which one I need.
12voltTRix's
draasch
Gold - Posts: 2,172
Posted: August 31, 2003 at 3:02 PM / IP Logged
yes you can use a meter to test the wire. i show it as a lt blue wire at the switch above the brake
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
12volttrix's
Member - Posts: 12
Posted: August 31, 2003 at 3:11 PM / IP Logged
All the diagrams show it as lt blue but the only 2 wires i have coming off it are pink and brown. what should i test for?
12voltTRix's
draasch
Gold - Posts: 2,172
Posted: August 31, 2003 at 3:14 PM / IP Logged
what does the remote start about the brake wire ???
does it need a pos. or neg. to shut down the remote start unit.
Good Luck
David
Ace Security
813-376-9778
Tampa
12volttrix's
Member - Posts: 12
Posted: August 31, 2003 at 3:20 PM / IP Logged
positive
12voltTRix's
goldfinger
Member - Posts: 38
Posted: August 31, 2003 at 3:29 PM / IP Logged
If the wiring diagram is the same as it is for a Grand Am the Pink and Brown wires you are referring to go to the cruise control module.  I'm assuming it's the same because the brake wire is lt. blue on the Grand Am also.
On mine I had 2 switches, one which controled the brake lights and another that controled the cruise.  Make sure you're checking both...... they are in the same location with one just above the other.  The lt. blue wire is in a 2 wire plug and will show +12v when the brake pedal is pressed.
12volttrix's
Member - Posts: 12
Posted: September 02, 2003 at 7:32 PM / IP Logged
Thanks bud...i never thought of cruise...i was thinking more along the lines of having something to do with the abs or something. I'll go tomorrow and check for another switch...Thanks again.
12voltTRix's
