Reset my remote car alarm
tubbscarol
Posted: September 17, 2003 at 11:06 AM / IP Logged
For some reason my car alarm do not recognize my remote, I have change the battery in the remote and it still will not work, My car alarm is called nobody messes with IT JT series the model JT2, this was installed in 1997 the place that installed it is no longer in business. I have gotten on line and found the name of the company and called the number for some kind of support, it was the wrong number. I need help really bad if anyone has any idea on what I can do to salve this problem I would greatly appreciate it
Thank You
xCarol
Reset my remote car alarm -- posted image.
Platinum - Posts: 12,488
Posted: September 17, 2003 at 11:13 AM / IP Logged
It may be soemthing as simple as reprogramming the remote to the CPU. I have never heard of this company before but is there an FCC ID number on the CPU casing or on the remote control ?
tubbscarol
Posted: September 17, 2003 at 11:34 AM / IP Logged
Yes there is a number in side of the remote control but it does not say FCC ID it    is just some numbers. I would gladly give you the numbers from the alarm remote when I get home. The only way I knew the name of the company I did an internet search with nobody messes with IT, which is the name that is ingrained on my remote control. I do appreciate your help. Reset my remote car alarm -- posted image.
Thank's
Posted: September 17, 2003 at 11:47 AM / IP Logged
Here is a site that may help you find out the reprogramming instructions. http://www.adelcom.net/JTI1.htm
They sell this alarm from the looks of it. Try them out first and see if they can help you out.
tubbscarol
Posted: September 17, 2003 at 2:05 PM / IP Logged
This is the web site that i call and it was a wrong numberReset my remote car alarm -- posted image. I even emailed them but I diden't get a reply.Reset my remote car alarm -- posted image.
Thank's Reset my remote car alarm -- posted image.
Scott35
Silver - Posts: 258
Posted: September 17, 2003 at 3:42 PM / IP Logged
According to my instructions, Valet mode code learning-turn the ignition on and the valet switch on. Next press button 1 of the remote control for 5 seconds while simultaneously pushing the door pin switch 3 times. The siren will chirp 3 times to confirm that the code has been learned.
Tacomacrew
