Car remote starts, then shuts off
ottobell22
Member - Posts: 13
Posted: September 17, 2003 at 6:50 PM / IP Logged
I have installed the hornet 554t. After remote starting the car it runs for about 3 - 5 seconds then it shuts down. The car runs fine if I use the key to start it.
Pioneer/JL audio XRs,W7 Orion Hcca/DEI Hornet
NowYaKnow
Gold - Posts: 1,217
Posted: September 17, 2003 at 7:04 PM / IP Logged
What kind of car? Did you use a bypass? If you leave your key in the ignition (not turned or anything just stick it in) and remote start it does it stay running?
ottobell22
Member - Posts: 13
Posted: September 17, 2003 at 7:21 PM / IP Logged
1)1996 honda civic HX coupe.
2)Don't need a bypass.
3)Didn't try that.
It could be that I have the ing #2 and the accessory wires mixed up. I got a wiring diagram from bulldog security which listed the ing #2 wire as yellow and the accessory wire as WHITE/ black, but on this site it is the reverse. That could be the problem.
c2deez
Copper - Posts: 71
Posted: September 17, 2003 at 8:50 PM / IP Logged
If the car actually starts then your ign and acc wires are fine. More than likely the r\s is set to current sense instead of tach sense mode. Once the vehicle starts, the r\s unit does not "realize" the veh has started and therefore cycles out to try the sequence again. Try switching to tach mode or at least change the threshold to a lower setting for the current sense.
Hope this helps.
Platinum - Posts: 12,488
Posted: September 18, 2003 at 12:51 AM / IP Logged
Definitely a tach issue
ottobell22
Member - Posts: 13
Posted: September 18, 2003 at 7:01 AM / IP Logged
D**m.............I didn't put the jumper in the tach threshold setting. I'll try that.
ottobell22
Member - Posts: 13
Posted: September 18, 2003 at 9:27 AM / IP Logged
I changed the jumper setting to tach threshold on and it still is cutting off................the voltage actually reads like 1.7 at iddle.
cpgoose
Gold - Posts: 1,098
Posted: September 18, 2003 at 9:30 AM / IP Logged
I had (have) a similar issue. We installed a r/s in my friend's '97 Civic, and programmed it for tach. It's worked great for a year. He just got a new car battery put in, and now when he remotely starts it, it like "skip starts", and then dies. It doesn't even start. So I think it might have reprogrammed itself back to "tachless" from the new battery.
Q: What's the best nation in the world?
A: Donation!     Donate to the12volt.com
ottobell22
Member - Posts: 13
Posted: September 18, 2003 at 9:36 AM / IP Logged
How can I program it for tach sense? I've changed the jumper to tach threshold.
ottobell22
Member - Posts: 13
Posted: September 18, 2003 at 9:51 AM / IP Logged
I see in the installation manual how to programe the voltage to low........................I think it will work now.
Thanks.
