where 2 mount 2-way pager alarm antenna
2000vsm
Copper - Posts: 65
Posted: July 15, 2002 at 7:28 PM / IP Logged
I got the aladdin a-2000.. it's a big unit.. wondering whree can i mount it so it's hidden but also good range... cuz right now it's in my sunvisor clipboard and the range is crap...
Platinum - Posts: 12,488
Posted: July 16, 2002 at 12:59 AM / IP Logged
Hey 2000vsm, did the sales person tell you about the resistor to cut to get 2x the range on the module ? If you can, take the casing apart on the communication module and slip the board between the roof liner and the roof.
TheRapture
Copper - Posts: 208
Posted: July 16, 2002 at 1:34 PM / IP Logged
i've got my 2-way FM antenna in the upper part of my dash above he insterment cluster... should i try taking out of the case also?
it's an Black Widow 2-way
Posted: July 17, 2002 at 12:38 AM / IP Logged
I'm not familiar with the antenna that the Black Widow comes with , but the Aladdin antenna's have a bulky casing that you can unscrew 4 screws and take out the board and it is 1/3 the thickness and 3/4 of the size. If the Black Widow has a case simliar to the Aladdin, I would suggest taking it apart so that you can fit it in smaller spaces and hide it better.
2000vsm
Copper - Posts: 65
Posted: July 17, 2002 at 10:04 AM / IP Logged
what resistor.. is it in the brain, like under the board there is this soldered resistor.. do i cut that one? i want more range.. sucks right now
hey if i hide it.. how can i press the button?
is it ok to put it in my glove box? there's not much metal there..
2000vsm
Copper - Posts: 65
Posted: July 17, 2002 at 11:55 AM / IP Logged
need the 2x range!!
Posted: July 17, 2002 at 1:08 PM / IP Logged
The resistor is in the communication module. There is a silver piece of tape on the side covering the resistor..... just cut it away from the module.
2000vsm
Copper - Posts: 65
Posted: July 17, 2002 at 2:38 PM / IP Logged
just cut it away like cut it in half or take it out completely??
also i opened up some of my brains of the a2000 and there is a resistor soldered on the back side of the brain.. what is that for?
Posted: July 18, 2002 at 7:20 AM / IP Logged
Doesn't matter if you cut it away or if you just cut in half. As for the resistor in the CPU..... we don't go in there, voids your warranty.
2000vsm
Copper - Posts: 65
Posted: July 18, 2002 at 12:06 PM / IP Logged
how about i put the antenna inside my sunvisor. like take out my mirror in the sunvisor and put it there.. or in my glovebox area?
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
