autopage 405a help
huzza
Posted: October 21, 2003 at 1:40 AM / IP Logged
Im a newbie and need help with installation. I hooked up all the wiring and only managed to get the parking light working.
1. Actuator didnt work. I have the 2 wires actuator and connected them to the unlocked/lock motor wires (common 30) on the brain. Didnt use the lock/unlock switch (NC 87a) , as im using an aftermarket actuator. The Blue Connector left with 2 wires, unlock/lock (NO 87) which i wired to 12volt constant. The manual stated that "coil contracts are not needed as they are controlled within the main unit"
2. I connected the (-ve) trigger input and (-) trunk trigger input to the right wires on my Honda CRX. Checked the color of wires too. I left the (+ve) trigger input unwired.
3. Didnt understand whats the Ignition Input (White) wire for.  Left unconnected.
Help and explanation would greatly appreciated. Thank you!
Platinum - Posts: 12,488
Posted: October 22, 2003 at 1:45 PM / IP Logged
1. If this has internal relays for an actuator wire it up like this
  • Common 30 from harness goes to BLUE and GREEN wires on the actuators. One for each
  • 87 N/O goes to 12 volts power
  • 87a N/C goes to GROUND
2. (-) trigger input is for the doors and the (-) trigger trunk goes to the light in the trunk. Make sure that the trunk light is a (-) trigger system as well off the light switch. If not use a relay and reverse polarity
3. Ignition input goes to the BLACK / YELLOW wire at the ignition harness or a switched ignition fuse by the fuse panel. THis is to let the alarm know that the car is running and the system will not arm when running.
huzza
Posted: October 23, 2003 at 12:15 AM / IP Logged
Thank you so much!!
I got the actuators working. I didnt GROUND the 87a N/C wires!!
Will check my trunk trigger wire again.
Wired the ignition wire to the ingnition harness and got everything working!!
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
