Adding actuator to subaru door lock
ldollahan
Posted: November 05, 2003 at 11:40 AM / IP Logged
I have a remote start/keyless entry for my 91 Legacy. The remote start is hooked up & working fine & I want to hook up the actuator for the door lock. I have the actuator, relay, & wiring diagram, but I need some info on physically installing the actuator. Any diagrams or instructions would be helpful.
brivalen
Member - Posts: 31
Posted: November 05, 2003 at 12:58 PM / IP Logged
most likely you will just have to eye it up - open the door panel, find a place for the actuator so that the window will go up and down and the door panel will go back on also and your all set
ldollahan
Posted: November 05, 2003 at 1:02 PM / IP Logged
Ok, thanks. I didn't know if it would be that simple or not. I'll just have to give it a try! Adding actuator to subaru door lock -- posted image.
