Sebring Trunk Help
oscarbengin
Member - Posts: 16
Posted: November 10, 2003 at 7:41 PM / IP Logged
To Whom Ever Can Help!!
I have a 2001 Sebring Coupe with a remote start/alarm. I accidentally put a straight ground to the trunk wire instead of doing a 5-wire alternating setup on the trunk wire when I installed it. The horn started going non-stop and a bit of smoke came out of the dash. I had to pull the horn fuse out to make it stop working. Now the factory remote won't even activate the trunk. Do I have to replace a brain in the car or did a meltable link become active? Is this going to be cheap to fix? Thanks for your help everyone!
Oscar
auex
Platinum - Posts: 5,041
Posted: November 10, 2003 at 7:46 PM / IP Logged
You let the genie out? NOOOO!!! First and foremost you need to have the BCM ( body control module) checked out, it is basically the computer that controls a majority of the non engine related functions of the car, including factory keyless entry. Last time I checked a new bcm for a dodge/chrysler was around 800 dollars.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
oscarbengin
Member - Posts: 16
Posted: November 11, 2003 at 7:53 AM / IP Logged
Could it be a relay that is stuck open or closed? My wife is going to kill me if I have to replace that BCM. The best price I could find for one is $450.00. Thanks for your help!
auex
Posted: November 11, 2003 at 4:12 PM / IP Logged
Chances are, are that you blew not only a relay but some of the traces on the board. You could always open it up and see what condition it is in.
italnpimp59
Silver - Posts: 427
Posted: November 11, 2003 at 7:13 PM / IP Logged
if im correct, that trunk pop requires a negative pulse, so you were supposed to use a relay.  what did u mean by a straight ground?
oscarbengin
Member - Posts: 16
Posted: November 16, 2003 at 11:22 AM / IP Logged
I got everything all working now. I did burn the BCM a little bit but totally repairable. Thanks for your help!
Haku
Copper - Posts: 204
Posted: November 16, 2003 at 8:26 PM / IP Logged
Lucky, lucky man.
Glad its working.
Hak
Siemens Autostart
mazdatruckin
Copper - Posts: 69
Posted: November 17, 2003 at 1:35 PM / IP Logged
italnpimp59 the trunk/release is 5 wire on all models.
