doors won't unlock when door shut
inacoma
Member - Posts: 9
Posted: November 12, 2003 at 10:32 PM / IP Logged
I have just installed a crimestopper informer car alarm/remote start.
turning on and off the ignition will lock and unlock doors as planed.
...then if I keep the door opened after doing the above, then I can unlock and lock via the FOB.
...if I shut the door, then I can only LOCK the door and it won't UNLOCK.
any help greatly apppreciated
it's on a 96 toyota landcruiser that had a factory alarm
kumar
profuse007
Gold - Posts: 2,015
Posted: November 12, 2003 at 11:25 PM / IP Logged
|     POWER UNLOCK|blu/yel & blu/org *2|- |driver door harness in kick |
*2 Both wires must be used and diode isolated.
see if this helps
Houston,TX
inacoma
Member - Posts: 9
Posted: November 12, 2003 at 11:44 PM / IP Logged
currently i have it hooked up to:
lock: GREEN/ red
unlock: blue / YELLOW
...and I used he diodes that came with the kit.  With the "white bar" on the diode on the alarm brain side.  Soldered all connections.
...so what you are saying is there is one wire for lock, but TWO wires for UNLOCK.  total 3 wires, 3 diodes.  I have some extra diodes, but not sure what size to use.  any recommondations?  and do I have it correct that I need to find a third wire?
thanks!
kumar
profuse007
Gold - Posts: 2,015
Posted: November 13, 2003 at 12:00 AM / IP Logged
diodes(1n4001)-youre correct
yep, toyota have this safety thingy.... so you need both wire total of 3 wires for unlock and lock
goodluck!!!
Houston,TX
inacoma
Member - Posts: 9
Posted: November 13, 2003 at 4:19 AM / IP Logged
Profuse007,
I looked all over for the blu/org wire, but did not find.  So I took what you told me about a third wire and looked through my wiring diagrams and compared it to what was on the stock alarm plug.  I found something called "door unlock detection SW Front LH".  I said, what the heck, let's give it a try.  IT WORKED.  The color:  Light Green (almost seafoam green).  So add that to the cranium for future installs :)
thanks again for all you help!
k
profuse007
Gold - Posts: 2,015
Posted: November 13, 2003 at 9:38 AM / IP Logged
dude, you stayed up all night to finish this installation?
what a soldier.....
Houston,TX
inacoma
Member - Posts: 9
Posted: November 13, 2003 at 6:50 PM / IP Logged
actually i work nites and did it when i got off work.  however, i have a new issue and may need to look for the wire you mentioned.  but lets see what you say first.
unlock and lock works till the cows come home EXCEPT...after this:
remote start, don't open any doors, kill remote start from the remote, unlock then DOES NOT work.
Kumar
inacoma
Member - Posts: 9
Posted: November 14, 2003 at 4:53 PM / IP Logged
well...I found the Blue/orange wire and hooked it up. I still have the same problem I did as mentioned in m last post.   Still can lock and unlock normally except after a remote start and stop from the remote...after that I can't unlock from the FOB>  :((
is there any other wires or possibilities I should be looking at?
thanks!
Kumar
defective
Silver - Posts: 642
Posted: November 15, 2003 at 2:04 PM / IP Logged
ohh man you're in deep.....grin...  i think i can help.
According to "The Book" by Omega:  "Some doorlock systems, however, require more than the 250ma. ground output that the security system's control module accomodates."
use a relay to give the Unlock a better ground point. Hope this helps
inacoma
Member - Posts: 9
Posted: November 15, 2003 at 5:51 PM / IP Logged
well...i just closed up the truck.  I went ahead and diasabled the auto lock after FOB start feature.  that fixed my child lock problem.
Next Time I open things back up, I'll try what you said.
thanks!
kumar
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
